saltbeEFE-full fat aircooled-
Started by beerbellykelly, January 10, 2012, 01:20:11 AM
beerbellykelly
tom, those aren,t our struts-just mock up blanks to set the ride height to suit the riders-
considering how well fed i am , and plan to continue to be so-our BSW struts will be a lot more subtaintial- :mrgreen:
check out the drag bike buzz built above , says more than i can here. :cheers:
GOD BLESS THE HUMMIN' CUMMINS
www.jamesandfriend.com
Buzz Lightbeer
Headlight & rev counter mounting on the headstock
Buzz Lightbeer
The headlight/revcounter bracket, this will also have the coils mounted on it as well. The reasoning for this is that they will be away from any electronics so rfi won't cause any problems.
Buzz Lightbeer
Revcounter mounted
Buzz Lightbeer
more
Buzz Lightbeer
Another view with the headlight mounted
beerbellykelly
love the looks of a traditional BLUNT instrument-
Buzz Lightbeer
Tom, here are the proper struts we are using. They are 21x31mm solid EN24T & the top mounting bar isd solid 22mm EN19
Koncretekid
Struts look much more substantial now.
If you don't mind me rambling a bit, I'll tell you what I don't like.  I look at that humongous gas tank and think, "That thing's in the way - - can't get my upper body and head down very low."  Then I look at your nice instrument mount/ "headlight" and think "that things in my sight plane, especially if I make a special flat gas tank."
Just thinking out loud.  A lot easier to make changes now than later.
Buzz Lightbeer
I know what you're saying Tom, but we want it to look like a stockish looking 1980's Suzuki GS1100.
If we was building an all out saltbike it would be a lot different, but we like 1980's aircooleds both GS's & Z1's. Now if I take off these rose tinted glasses  :-D
Koncretekid
Buzz,
Are you running "M" class or "A" class?  Length of swingarm may make the difference (more than 10% increase in wheelbase will bump you into "A" at SCTA; not sure about BUB/AMA).
I don't blame you for wanting the traditional look :cheers:
ol38y
Re swingarm, as Tom said 10% for SCTA and with BUB, if you build it from the stock swingarm it's ok. If you build it from scratch it makes you A. That's what I was told when I asked. Also, if you run A in SCTA, forget about the headlight, cuz you can't run one. I'll second the vote to change the gas tank as well. Good luck.  :cheers:
Larry
Larry Cason
2010 BUB 1350 M-PG record
Buzz Lightbeer
Tom, Larry, the arm is a standard Suzuki arm with extensions so I will have to have a measure up, is that +10% of the original wheelbase?
Granted the fuel tank ain't pretty, PJ has another one with the back cut off to follow the frame tube so will pick that up at our meeting on the 28th of this month & see what that looks like, thanks for your help & interest.
Dave
Koncretekid
SCTA 2012 rule changes are listed on the "news" section of the landracing.com home page.  Scroll down to new rules, then click on "more".  New frame rule reads as follows: "A maximum wheelbase not to exceed the original OEM specification plus 10%. Entrants shall provide acceptable documentation for record certification."
Dr Goggles
Quote from: Buzz Lightbeer on January 15, 2012, 09:51:25 AM
Hey Lightbeer,make a tube tank with just enough room for a runs worth and then make a mock tank out of rubber foam exactly the same dimensions as the stock tank....that way it looks original AND you've got something comfortable to rest on while in the racing crouch.....
That's OK, thanks  :wink:
