saltbeEFE-full fat aircooled-
Started by beerbellykelly, January 10, 2012, 01:20:11 AM
beerbellykelly
with four months until we need to crate and ship the across the pond-with parts still appearing from all points of the compass-the one off parts piling up fast-and way too many other builds taking up time , dave [buzz lightbeer ] and myself thought it high time we added a few pictures of how things are shaping up-
GOD BLESS THE HUMMIN' CUMMINS
www.jamesandfriend.com
beerbellykelly
#1
the bike has been in my ownership for about twenty years-and has variously been powered with 750/1000/1100/1170/1260 motors , all aircooled suzuki , it has been street raced , drag raced , bracket raced , impounded and fallen off of , all over europe , so when dave suggested we build a proper old skool  aircooled multi - i had a lot of parts to throw in the mix-
dave has called on his many years of drag racing and metal fabricating to bring some great sponsors to help the bike - [mostly from the usa]
this has helped us a great deal in getting parts at sensible money , as to build something like this from locally sourced parts would be prohibitive.i am lucky to have the keys to AIRCOOLED WONDERLAND-which makes stuff like cases , cranks, heads etc-plentifuel.
the bottom end of the motor is gsx1100 EFE[1135cc]-the toughest out there , to this we added a *DAVE BRANCH* -england- pro mod/funny bike crank , an *R & D* -florida-  transmission , and a WISECO 1327 big block -we used a GSX1100ET[1074cc] cylinder head [the earlier heads have deeper port floors and dont require resin building] this head was fully skulled by MRE-
i will let dave write up the full spec of the motor-
the first two pictures are with our mock up motor,and setting ride height,rider posistion etc.
beerbellykelly
while dave was left in sunny england to work out the science , and blue glue the frame together how we wanted..
beerbellykelly
i had to race this potent triton in rain soaked france-dave was left alone with some choice goodies to keep the bike happy-
beerbellykelly
#4
we have both tried to use the best parts we can lay our hands on to get this 29 year old , blunt instrument down the ghreat white dyno
in the fashion were used to-
i have to say the R & D MOTORSPORTS transmission , is really a work of master craftsmen , it deserves only the best 10w40-
i,ll let dave describe the cylinder head..im bound to get carried away. :-P
oz
Buzz Lightbeer
As BBK has started the build diary, here is the spec of the motor.
1327cc forged MTC pistons now machined to 12:7 to 1 static compression, Wiseco bigblock with LA Sleeves O'ringed , GS11OO ported bronze skulled head, with 31/26 Ferrea stainless valves, Kibblewhite valve springs with GSXR1100 rockers & Megacycle cams all the head & piston work has been done by Jeff Reel of Reel Race Services it flows 140+cfm. The head was supplied by Jay Reagan owner of MRE, who also supplied & prepared the bigblock for us.
GSX1150 crank & clutch with straight cut primary gears, both prepared by my friend Dave Branch of DB Engineering. Dave also made the belt drive alternator bracket for the bike to.
Kevin at Lectron Fuel Systems personally built a set of 44mm powerjet carbs for us, once he knew the spec of the engine.
Mark at R&D Transmissions fully prepared the gearbox & shift drum using ceramic bearings supplied by Big Dave at Worldwide Bearings.
Dawson Motorsports have supplied us with a top end oiling system, single stage lockup clutch, dyna ignition, pnc300 nitrous controller & all the nitrous components as well as many other parts.
We have converted the the chain & sprockets to 530 pitch instead of the extremely heavy original 630 pitch
A lot of the engine components have been DCT'd this includes the crank assembly, camchain, final drive chain & split links these are actually being shipped back to me on Friday.
Buzz Lightbeer
the beginning of the project
Buzz Lightbeer
As you can see in the previous pic we had a shock absorber offered up, but in the end we have gone with a rigid set up.
Here are some more pics
Are you sure?  Good suspension is the key to eternal hoppiness.
Nortonist 592
Quote from: beerbellykelly on January 10, 2012, 01:56:58 AM
Life is tough isn't it?
Buzz Lightbeer
Wobbly, the reason for going rigid is that to put all the bracing & mounts in for the shock linkages.  It would mean a hell of a lot of work removing some tubes & replacing with thicker wall tubes. Plus the shock absorber would have taken up vital space needed for the nitrous system & bottle, these old frames are very restrictive to try & fit everything in, unlike my dragbike with its bespoke frame
Buzz Lightbeer
heres a pic of the frame stiffener
Buzz Lightbeer
another of the stiffener with the old weld ground out
Koncretekid
Buzz,
The struts you are using to replace the suspension look a little on the weak side.  If your bike weighs 600 lbs fully loaded, then there will be approximately 300 lbs at the rear wheel.  Your struts are somewhere near the middle of the swingarm, therefore the load will double to 600 lbs.  Because the struts are not vertical, the load will again be increased.  The struts are considered long columns.  Long columns fail by buckling, usually without notice once they start to deflect.  I can't tell you what size you need, but am just cautioning you to consider these struts more carefully.  Any structural engineer could do a quick analysis and tell you if they are strong enough.
