New Bike Frame Project
Started by 55chevr, April 02, 2012, 07:39:14 PM
Frank06
I would think a small radiator would work fine for paved tracks.  Longer runs would take some more thought though.
E-Racer
Jessechop
I looked at the YZ radiators this morning. The right side radiator I think would work well with minimal work...I think. All though, to mount it the way I envision the radiator cap would be on the side....hmm
55chevr
Finished the rear brake setup.   I used a Sportster rear master cylinder.  They seem to work well for me and are easy to mount with an integral reservoir.    Kawasaki ZX7 rear caliper.
55chevr
Also have the shifter completed.
55chevr
The radiator is a trial fit.  Stock it too high and too big.  I will need to find a solution.
Jessechop
What does the small hose from the radiator go to?
55chevr
The small hose goes to an oil cooler.
saltwheels262
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
Jessechop
Years ago I build a pull tractor with a liquid cooled snowmobile engine. I used a radiator off a CX500..I think. That radiator would fit up in the frame, then just a matter of running lines to a cooler for the oil, if needed. Perhaps a small oil cooler like the XB's use would suffice on that end. Let me do some digging to see if I can figure out what I used.
55chevr
The oil filter base is a heat exchanger using engine coolant from a water pump bypass.  The hose runs from the water pump to the oil filter base and then to the radiator.  I have a radiator from a CBR250.  It is tiny and the hose connections are small.  Best option might be to cut down the stock radiator.
55chevr
It rolls ... next is getting it running
What a great looking bike Joe. It scares the heck out of me just standing still. Well done!!!  :cheers: :cheers: :cheers:
sofadriver
Looks great!
Making it a roller is a big milestone. Congrats!
Mike in Tacoma
Bike #833
saltwheels262
that is very nice. a metric engine in a custom rigid frame.
sitting next to a 69 charger ?
                            - franey  8/2007
55chevr
The Charge Dodger is Steve Von Blarcom's.  Real deal 440 Six Pack.  I brought the bike to Steve's annual Land Speed open house at his shop.
