New Bike Frame Project
Started by 55chevr, April 02, 2012, 07:39:14 PM
55chevr
Steering neck ---
40* Rake
Tacked in place
55chevr
There is 2" of travel in the rear axle sliders ... should do most any chain adjustment ... will take up to 4" of chain differential
the resemblance to Oz frame is not an accident.
Jon
Great work & progress Joe, blinked and there was a complete frame :-o
You be riding next week?
Cheers
jon
Underhouse Engineering
55chevr
4 tack welds on tubing joints is not recommended for land speed racing.   I need to get my son over to tig it for me.  He worked 4 years on a NASCAR team as a fabricator and he is a skilled welder.   Plus there are a lot more tubes to be cut and fit .   Maybe 2 weeks.
oz
racer
Great job.
Ride safe, fast and forever....
Ray C Wheeler
stay`tee
Joe, how have you locked the steering neck locators in position onto the jig, :?,, nice job, doin well, :cheers:,,
55chevr
I bought the neck fixture from MechWerks .... the taper cones have a set screw to lock on the shaft.  The neck has a lot of work in it ... the ZX9 Kawasaki bearings have fairly large OD and had to machine out a lot steel from a piece of bar stock .... The rest of the jig I built.   Nice working on a steel table. Leveled the table, then leveled the channel stock rails and tacked them to the table. Same with the neck fixture. Got it plumb and then tacked it into place.
Tman
stay`tee
Thanks Joe,, i have built a number of dragbike frames, my steel table jig utilizes a neck holder similar to yours, the difference being that it has a 3/4" piece of Booker Bar (threaded rod), with the neck and locaters in place its just a matter of screwing the nuts in against the locators,,
saltwheels262
joe,
that looks nice.
do you think it'll be ready for july at limestone?
bill
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
55chevr
Bill - that is the plan ... I was going to try for Ohio but decided that it wasnt feasible and slowed the project down.   Makes it fun instead of work.
TwinSpin
I am quietly watching your build, especially the jig and head post. I plan to make one for my first bike build too.
Thanks for educating me. Your pictures are clear and show the details I need to learn. My appreciation.  :cheers:
55chevr
The frame was originally designed by Oz ... I know a good design when I see it ... He was gracious and even sent me some double secret photos of details. I suggest you check his threads "My CBR1000 AF" and "My CBR1000 AF - again".   The jig and post stuff is basic chopper stuff. Simple design and very effective.  It is downsized car chassis jig similar to what Nascar teams use. I have larger jig of similar design under the Model A.  I found that dial levels are a little easier to use than bar levels. A string line is needed to center the rear axle on the steering neck.
