New Bike Frame Project
Started by 55chevr, April 02, 2012, 07:39:14 PM
55chevr
Cut a lot of the diagonal braces and tacked them on ... Need my son to come over and tig the tubes together.  I can't go much further until it welded strong.
38flattie
Joe, it's coming along great!
It's pretty cool that Oz shared his design with you! :cheers:
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
oz
I was very flatterd that it was liked enough to be imitated and the fact I was asked! the least I could do was to try and help if I could,
I reckon its coming together excellently.
Cheers Oz
38flattie
Quote from: oz on April 17, 2012, 01:38:35 PM
Cheers Oz
:cheers: :cheers: :cheers:
55chevr
Oz,
I know the goods when I see it.  Asking is just the right thing to do.
Frank06
Very impressive Joe.  Do you have a tubing bender and if so, any chance of showing some info about it?  Can I ask about material size and specs for the frame?
Frank
E-Racer
55chevr
I worked off a 72" wheel base as it worked well on the chapman frame. Rail material is 1" x .090 DOM tubing.   The neck was machined from 1020 CRS round stock.  It is set up for stock ZX7 bearings which match the donor bike components.  I used a JD Squared 32 tubing bender.  Some years back I made an exhaust system for the 55 Chevy and I bent up EMT conduit for patterns.   It worked well then so I did that again.   The pictures that I got from Oz helped a lot.  The differences in Honda and Kawasaki engines created some design challenges but nothing too tough.  I cut the tubing and fit it together then tack it in place with a mig.  I need to get my son over to tig it.  He is a much better welder than I am.  Funny, I taught him to weld.
Frank06
I like the EMT idea, was wondering if PVC could work but EMT seems more robust.  Thanks for the info.
E-Racer
55chevr
Got some frame welding done today ...
Son came over and gave me a few hours ...
55chevr
My son Joe got the top side welded where it was accessible. I took the mock up engine out so he could get to the inside joints.  Tough to get him over as he has 5 children and someone is always playing baseball or hockey.
Need him for another 2 hour session and I can start on the motor mounts.
Frank06
Joe,
Any chance you'll be ready for Loring?
E-Racer
55chevr
Just cant tell ... I will have the frame welded and rolling with a stock engine by July. I just dont know if I can get it all done with the damn job getting in the way. I have a bunch of stuff in work and I might run out of time.  I am determined to get the 55 Chevy on the road this year. Too many projects too little time
55chevr
Got the kid for an hour today and making progress ...
ol38y
Coming along nicely Joe...  :cheers:
Larry Cason
2010 BUB 1350 M-PG record
55chevr
Larry -
Are you going to Bubs this year ?
