Brand new at this please help !
Started by taper41, May 24, 2012, 10:23:51 PM
taper41
 :cheers: I should send you a beer for this  :cheers:
fastman614
Larry, Larry, Larry, Larry.... lol!!!!! :wink:
And you, pretty much like me, "need" to know the why of that..... my man, I am going to leave that to you to figure out as the math has gotten, for me, to the point of "I now have to write it all out and slowly work through it with a paper and a pen!".... so.... I honestly hope you post any findings of the apparent "discrepancies" as I too am interested!
fastman614
Quote from: taper41 on June 05, 2012, 09:21:16 PM
Larry.... LOOK AT THIS OFFER!!.... I honestly think that taper DOES OWE YOU A BEER  for this!.... so, isf you go to the Ohio Mile, he really needs to show up and make good!.... and for probably several others at that venue as well... If at Speedweek, Larry, just look up the Canadians!.....and then somewhere in the cosmos, taper is going to owe me/us that body design I alluded to a while ago! :cheers:
fastman614
Seriously though, for a person who is studying engineering of any sort and for taper here who is into the aerodynamics etc. of automotive design, I would highly recommend that taper and all other engineering students in this field, get to places where high speed runs take place and for them to seriously observe.... and get information (possibly not at the site - but contact information of the competitors) and, during "lull" periods, get the real information.... stuff like horsepower, frontal area, gear ratios .... everything!.... and do any and/or all of us a huge favor..... help us out with the results of processing that information through your schools'(?) computers ....
It could also result in, if nothing else, better grades for taking it as seriously as this sounds....
taper41
Ill make good on the round for you fellas, and maybe a few more if he figures this out whether there is a slight advantalge with aero drag or if tere exactly equal .......either way
hotrod
I think I have figured it out:
The difference is an artifact of the percent of change in the ratios between the original and the modified power or drag.
At 25% change in drag or power, the difference is 2.17%, at 50% or 2x change the difference is .00000000.
It is because you are dealing with fractions in the ratios of original drag or power and final drag or power.
If the change in power or drag can be expressed as an exact integer change ie 2x rather than some decimal fraction like 1.25 or 1.33, the difference goes away. Too tired to go beyond that and what it tells us, but here are some other changes that show it is not due to the magnitude of the speed or even the size of the change but rather the fractional change from the original value to the final value.
(400 * 1100) / (.002373 * .30 * 25) = 24722573.4
cube root(24 722 573.4) = 291.316148 ft/sec = 291.316148 / 1.466667 = 198.624601 mph
(400 * 1100) / (.002373 * .30 * 20) = 30903216.7
cube root(30903216.7) = 313.810807 ft/sec = 313.810807 / 1.466667 = 213.961865 mph
(300 * 1100) / (.002373 * .30 * 20) = 23177412.6
cube root(23 177 412.6) = 285.11604 ft/sec = 285.11604 / 1.466667 = 194.397256 mph
198.624601 / 194.397256 = 1.02174591
(400 * 1100) / (.002373 * .30 * 40) = 15451608.4
cube root(15 451 608.4) = 249.071803 ft/sec = 249.071803 / 1.466667 = 169.821645 mph
(200 * 1100) / (.002373 * .30 * 20) = 15451608.4
cube root(15451608.4) = 249.071803 = 249.071803 / 1.466667 = 169.821645 mph
169.821645/169.821645 = 1.00000000
(800 * 1100) / (.002373 * .30 * 80) = 15451608.4
(800 * 1100) / (.002373 * .30 * 40) = 30903216.7
cube root(30903216.7) = 313.810807 = 313.810807 / 1.466667 = 213.961865 mph
(1600 * 1100) / (.002373 * .30 * 80) = 30903216.7
213.961865/213.961865 = 1.0000000
Larry
fastman614
Larry, Too late for me as well...
I am going to look at it tomorrow...
taper41
Quote from: hotrod on June 05, 2012, 11:01:04 PM
Larry
So no matter how you cut it, power and aero drag are of equal importance for max speed ?
tortoise
#233
. . . at 50% or 2x change the difference is .00000000.
Larry
Quote from: taper - modifiedif  you decrease the aerodynamic drag by 25% 50% or add power by 25% 50% would the result differ or be the same, if it was on the same vehicle?
The vehicle with the reduced drag is now 10% faster than the other one.
tortoise
Quote from: taper41 on June 06, 2012, 07:09:50 AMSo no matter how you cut it, power and aero drag are of equal importance for max speed ?
Yes
McRat
SCTA-BNI LSR records are based on a ruleset that dictates limitations.  Most limits are to the car body.
Hence, pragmatically, if you want to go faster legally, you need to add HP.  There are no HP limits.
And ...  You can make brick go supersonic with enough HP.  This is why they have truck classes and roadster classes.
tortoise
#236
Quote from: McRat on June 06, 2012, 07:33:38 AMSCTA-BNI LSR records are based on a ruleset that dictates limitations.  Most limits are to the car body.
Tighten up the body gaps. Get the stance right. Big difference. Cheaper than horsepower.
taper41
#237
Quote from: tortoise on June 06, 2012, 07:16:50 AM
Yes
so decreasing the aero drag on one car by 50%,  then reseting all values back to original, then adding 50% power , you reach the same 10% increase in speed.
Wait so you are actually agreeing with hotrod, tortoise that power and drag are of equal value for maximum speed ?
McRat
Naw, just pump 75psig boost into the engine, and hope the body panels don't tear off.  :evil:
tortoise
#239
Quote from: taper41 on June 06, 2012, 08:41:27 AMWait so you are actually agreeing with hotrod, tortoise that power and drag are of equal value for maximum speed ?
What part of "yes" don't you understand?
Note: my reply #233 is still correct.
