Brunskilltown Bullet
Started by DLRA#363, May 06, 2013, 04:32:48 AM
rouse
Quote from: DND on May 07, 2013, 10:28:50 AM
Hi Rouse
Had two friends that worked the Milodon nite shift welding up those main cap girdles, as he sold a bunch of them for keeping the crank in the block.
You also needed a knoched pan to match the gasket rails.
Those folks at Milodon had a lot of good stuff for the old early hemi's. I ran a girdle early on and later they had 4 bolt main kits that we went with. Made the pan a lot simpler, but with the heavy clutches we ran, it didn't help much for the rear main. I not sure how many time I pulled the pan and found the rear main cap spit in half. Never hurt the bearing or crank (?), don't ask me why so we'd find another rear main cap and bolt it in.
In the early sixties Papa Jack Roberts in his old dodge "Green Machine", along with Jim Short and Karol Miller in their Fords, Left out of Angleton, Texas and drove to Bonneville (1,830 Miles), raced their cars and drove
back home. Papa Jack ran as fast as 156+ on the salt with his daily driver, early Hemi in the old Green Machine.
Rouse
Johnnie Rouse
DLRA#363
Quote from: grumm441 on May 07, 2013, 05:37:41 AM
From the pics, it also looks like you will be running rear suspension
Or is that just for adjustable ride height?
Colonel,
Plan is to run suspension on the rear with the option of installing set length struts in place of the coil overs if desired.
DLRA#363
#17
Work on the front suspension is progressing well. I have decided to settle on around 23° caster angle to start with.
Still waiting on the Strange Eng. 20:1 Stiletto steering rack.
Only have to fit the Panhard bar to the rear end (tomorrow's job).
grumm441
I looked at that first picture and thought  "neat"  then I realised it was the front end
Watts link on the front. Clever
We are running 30° caster on the front.
My drive this year didn't get far enough for me to say how good it is
However, Goggles assures me it's so stable that all it needs is a side window to fat arm out of when its doing 200
Great workmanship on what you have done so far. What is your thinking on the body shape?
DND
Hi Bullet
After seeing your neat front axle Watts Link i would think you would make one of those for the rear end too?
With your frame rails so close together arn't you concerned about the rear moving back and forth using such a short panard bar, where a watt link would keep her dead on center all the time.
Very nice build!!
DLRA#363
Punching the figures into the CAD program show a somewhat significant minimal reduction in directional stability by using the pan-hard bar set up in the rear end Vs the watts set up the front end.
Suspension travel should be in the vicinity of 1½" maximum vertical and whilst the front end is considered critical.
Speed Limit 1000
[/quote]
Quote from: DLRA#363 on May 13, 2013, 04:05:32 AM
??significant or minimal??
Frankie7799
Question for you. Are you planning on putting some kind of aluminum spacer between the manifold and the injector so it can sit up and out of the body to allow it to breath or are you planning on running some kind of ductwork down to it?
DND
Hi Bullet
Why would you wan't the rear to move at all, since you are building your car from scratch why not put in the best locating set up you can?
DLRA#363
Quote from: DND on May 13, 2013, 12:31:47 PM
Hi Bullet
SOLD - Watts linkage going in. :-) :-) :-) Watch this space :roll: :roll:
Good choice, movement in the rear actually steers the car more than movement in the front... don't ask me how I know but we fixed that issue in 2001 and the car has not taken off on its own since.  Panhard is gone, triangulated the 4 link.
DND
Sounds good glad i helped in your set up
DLRA#363
The Wilwood brake pedal assembly arrived this week and the decision was made to stretch the car by 250mm (10 inches)  :?
Best time to do this is now so the changes are underway. :lol: :lol:
From this:
To this:
Enough extra room now to carry a passenger.  :roll: :roll: :roll: :roll: :roll: :roll:
if you think you need to stretch it 10 inches you better stretch it 20... you only want to do that once.
