Springfield Flyer.
tauruck
Arms bolted on. Top one polished for coating.
I collect bolts Friday.
tauruck
I'm having a problem on my rear end. The liner's that is.
I wanted to upgrade to bigger outer bearings (Timken 514003)
which is much larger than the current Mustang 9".
I just measured and my axle OD is smaller than 1,531" for the Timken.
My axles measure 1,366". I can get metric bearings that run at very high load and speed
but they measure 35mm which is a shade (,26mm) too big for the Mustang axle. :dhorse:
Mike, that top plate, is it held on by those four allen bolts, only?  How does that middle bolt work?  I have not seen anything like that before.
tauruck
That C/S M16 bolt is temporary until I get the right bolts Friday.
My bolt sponsor is 100 miles away so we try to collect stock as
little as possible. The M16 is the main bolt that holds the components together. :cheers:
Flush Cap screw with a nut for Jamming??????
kiwi belly tank
Quote from: tauruck on September 05, 2016, 05:47:13 AM
Whats wrong with the stock bearing size?
tauruck
Quote from: SPARKY on September 05, 2016, 08:45:10 AM
The current bolts are too long and C/S. :roll:
tauruck
I've given 100% I think and i'm burnt out.
No comment on what Floydjer will say but I need a break.
The mental torture is too much. If I lived in the US i'd hook up with Gregg
and visit museums. I can't do that so fishing is my only option. :-D :-) :|
Gone fishing (if all things line up). :cheers:
Good luck Mike!!!  :cheers: :cheers: :cheers:
You'll come back refreshed!  :-D :-D :-D
if you put weights on the line they hang straight down, assuming no currents  :-D
Have fun
tauruck
No such luck unfortunately.
The holiday home is shared by family and the guy with the keys is away.
Guess i'm stuck here at home.
Good thing I stayed. Some goodies arrived. 1000 rivnuts and a tool.
My client Ashley bought the tool for his project but it's mine when the job is done.
Cool dude and so genuine. :cheers:
BTW, Sparky, I PM'd you about ratios. Need some feedback please?. :-D
floydjer
geeeeeeeeeez...I get bashed  BEFORE I can post a snarky comment ??  Mike, Just set fire to the open end of an Oliva serie V, crank up "Echoes' and the world will be a better place....Carry on, JB
tauruck
Because we LURVE you Jerry!!!! :-D :-D :-D :evil:
Mike, are your rivets stainless steel or carbon steel with galvanizing or anodizing?
tauruck
Normal carbon steel, cadmium plated for the client.
I have Ally for the liner.
