Springfield Flyer.
tauruck
Thanks for the advice Jack. I'll look into it. God Bless. :cheers: :cheers: :cheers:
Nice looking coil packs, Mike.
kiwi belly tank
Quote from: tauruck on September 14, 2016, 11:15:52 PM
Quote from: kiwi belly tank on September 14, 2016, 08:58:29 AM
You better be on the hunt for an 8.5 housing Mate!
After all work I put into the current one?????.
I thought one of you guys would have wised me up way back?.
Right now I'm not working on the project. Too dejected.
You have a 7.5, we assumed you were wised up on the difference, a quick Google search shows you how to id GM axles. The "you guys" here all run the 7.5 axle with a 2.14 factory gear.
tauruck
Busy on a plan Sid. Watch this space in a few weeks. :-D :cheers: :cheers:
kiwi belly tank
I don't follow every nut n bolt of your build or all the gum flapping, got enough of that here to suck up my time, I just pop in once in a while. Now your left hand is talking to you right hand I'm sure you'll get over this bump in the road, that's what we do! :x..... :|..... :-).
tauruck
Thanks Sid.
I know you're collecting wood for winter. I don't envy you one bit.
You're right, this type build isn't for sissies but I've shed a few long tears.
I'll get over the bump. Thanks for always being there for me. You're a true friend. :cheers: :cheers: :cheers:
kiwi belly tank
#2631
This one man road show can deliver a reality check with a hint of finesse.  :dhorse: Come on bitch....get up!! :-P
No wood cutting for me any more. I heat the shop with Jet-A now & get about 500 gallons/yr free from the airport (sump fuel) that is non flyable plus I mix that with hydraulic oil from an elevator company in Utah. Free-ish heat.
I'll call your free fuel and see if I can top it:  We sell a few truckloads of sawlogs of our land every four or five years, routing the $$ back through the buddy that cuts it.  He then cuts and hauls and stacks our wood for us -- and we end up about $500 to the good every year.  Of course -- heating with wood does mean that I visit the boiler (outside) three times/day -- for about six months.  You do the math and see how often I get to go out for fresh air.  Sure wish we could get natural gas delivered to us at the same kinda price. . .
tauruck
Quote from: kiwi belly tank on September 20, 2016, 10:04:15 AM
This one man road show can deliver a reality check with a hint of finesse.  :dhorse:Come on bitch....get up!! :-P
Good to hear that Sid. :-D Free-ish beats cutting wood. Good to know you'll be warm this winter. :cheers: :cheers: :cheers:
tauruck
Making progress on the side, not too much but lots in the pipeline.
Pics later.  :wink:
tauruck
#2635
Guys, Alex Banach from TD Coatings offered his company's services for my project.
Now there are a whole lot of parts I'd love coated but I want something other than paint or powdercoat
for the cool parts like front stub axles etc. I also hate  corrosion so I was wondering what you guys would suggest?.
I don't have big bucks like my contemporaries but my cars have always been the best turned out on fit, finish and paint.
I'm hell bent on keeping it that way. TD have many differing processes but I don't know what's best for my application.
I need advice please?. Thanks in advance. :cheers: :cheers: :cheers: :cheers:
http://td.co.za/
http://td.co.za/pvd-coating-article/
wheelrdealer
Mike:
I like nickel plating for structure parts and parts that get a lot of use. Nickel looks good and does not chip like paint or powder coat. It has that flat silver finish that has replaced chrome lately. Because it is not polished at the end I have found the labor cost is lower and thus cheaper.
my 2 cents.
Mike;
If you have access to electroless nickel plating, I'd recommend that for your parts. It will probably be limited to parts of a certain size due to the tank size of the plater. Electroless nickel is unique in that it can plate internal threads, blind holes, etc. I used it to plate the cylinder walls of a Corvair engine that I built. The plating hardness can get pretty high by heat treating. Pretty low friction coating, too.
Finallygotit
#2638
Quote from: wheelrdealer on September 21, 2016, 04:55:43 AM
Mike:
my 2 cents.
^^^^^^^ What he said.  And what Neil said.
I work with injection mold tooling and we use a lot of electroless nickel plating.  It applies evenly and won't chip like chrome and is fairly inexpensive.  You also have the option, within limits, as to how much plating you want per side.  HTH
Dan
Tucson, AZ
kiwi belly tank
One thing to remember here is Mike will be running on dirt not salt.
Anything structural needs to be regularly inspected so that needs to be kept in mind when it comes to coating or plating.
