Springfield Flyer.
tauruck
Progress on which car?????? :-)
WOODY@DDLLC
Neat as a pin?  :? We need photographic proof Mike!  :x
Anything you're doing is of mutual interest!  :cheers: :cheers:
floydjer
Yeah Mike..Pics of what ever.................. :evil:
tauruck
#2869
Kinda build related in that the day job pays for the liner so here goes.
NIGHTMARE OF NOTE!!!!. :x
The deal was Kyle wanted to build a Pro Mod to replace his all steel Mazda 3 aka Snowflake.
The story is that my turbo guy called Nassen has held the class record for the fastest FWD drag car in the Southern Hemisphere
since 2009. Kyle was next quickest. Some newbie got hold of the rulebook and found a loophole.
He built a genuine Pro Mod and came out of nowhere on his first pass and destroyed Nassen's record with a NA motor.
The car is about 400lbs lighter than both Kyle's and Nassen's all steel modified road cars.
The guys went into panic stations. Nassen almost lost his hand trying to lop off about 10lbs of bodywork!. It wouldn't have helped even if he succeeded.
Kyle decided to go Pro Mod and asked me to build the bodywork. His option was to borrow molds made for a BMW M3 made buy Boet Budler's workers.
No experience with fiberglass!!!!!!! :evil: :evil: :evil: :evil: :evil:
I didn't want the job. My advice was for him to approach Mazda and ask to loan a body in white that I could pull molds from.
He did and Mazda agreed to give him the body but the car had to be running at the track on April 1, the day they launch the 2017 Mazda 6.
Kyle could not meet the deadline so he begged and offered me a fair amount of money to use the Budler tooling and turn a Bavarian Murder Weapon into a Mazda.
Some guys see Dollar signs but all I saw was shiny new Mickey Thompson tires. Big mistake maybe!!!! :-o :-o :-o
There's also a Fueltech Ft 400 system sponsorship thrown in for good measure. I really like Kyle and he needs this so bad I couldn't say no.
The tooling was badly designed as far as rigidity and split lines go. Also no boxes built onto any of the six molds. I got motion sickness just laminating the door skins. :-D
I asked my young genius Denny to draw some overlays of the BMW vs the Mazda. He did that and the shapes are pretty close save for the blunt nose on the Mazda and the rake
on the BMW windshield. Budler had chopped and raked the roof already so "All" I had to do was build the main body and change the shape of the slope on the rear window, build in more Mazda like
side window recesses and cut out the trunk lid. :-D
It turned into a mission. Kyle's dream became my nightmare. Due to the mostly one piece mold design I had to cut the new body to demold it. Luckily I hadn't used a lot of material in the areas
that needed cutting. When I got it out after 6 hours of war it couldn't even stand on its own. It looked like a cow that slipped in mud. Spreadeagled all over the workshop floor. No frame work between
the A pillar and door sill?????.
I built a steel frame and bolted it to the body just so I could move it around, flip it over and do my work.
tauruck
#2870
I beefed up the roof panel with a high density foam cross for starters.
The sides of the body below the window lines were also suspect so they
got ribs too.
tauruck
Flipped the body over and got to work on the rear window mod.
Marked the areas to be cut and got into it with the CP ricprocating
saw.
I raised the side to where it needed to be and clamped it for a visual.
It looked right so I proceeded with the hard graft.
tauruck
With changing the slope on the window none of the lips for mounting
the Lexan are at the correct angle and will be cut out and new ones
laminated.
Pulled the body into shape with plates and Clecos. I the put the
heat lamp inside to warm up the Epoxy which helped it retain the new shape
and bear in mind that the material is pretty thin in these areas.
tauruck
Jumping to near the finished product it looks fine.
I need to remove the Clecos and then move over to the
left to duplicate the shape.
Good job Mike! That ain't easy.  :cheers: :cheers: :cheers:
Dr Goggles
With the flu too, you're a gun.
floydjer
You`ve done this before haven`t you??? Looks great Mike. JB
Mike, your effort to produce a decent body out of those molds reminds me of the old saying "Making a silk purse out of a sow's ear".  :-D
WOODY@DDLLC
Mike, see what you can do when you are afflicted with full-blown LSR desperation!  :-o :-o :-o :cheers: :cheers: :cheers:
Might be a market for Pro Mod Beemzas!  :? :?
