Springfield Flyer.
Harold Bettes
Mike,
I am sure that you are aware of some Ford 9" facts but it is worthwhile for you to review before you get too far along.....The 9" Ford rear end has a considerable offset (vertical) of the pinion centerline so if you have already planned on a pinion centerline (vertical) using a GM rear axle, the offset difference should be evaluated. :roll:
As far as the drawing side and supplying same to a gear manufacturer, it is perhaps possible to get those type of drawings from an existing manufacturer if you might ask them. However, having addressed the problem is far from solving it. Perhaps it is better to discuss the issue in detail with a manufacturer such as Meritor that indeed might have a ring and pinion already done that is very close to the ratio you say you want. Just a thought to perhaps ease the angst a bit. :-D
Stay safe and clear of the snakes. Both Mr. No Shoulders and the two legged kind as well. :-o
Best of Luck in the coming New Year. :cheers:
Regards,
HB2 :-)
floydjer
Speaking of 9 in. pinion/axle centerlines....Strange makes a 9 in. center section that uses G.M gear sets.
Interested Observer
One might also consider agricultural/industrial gearboxes for which a 2:1 ratio, and others, are likely readily available.  This would, perhaps, complicate the "axle" part of the problem though.
I got ripped off to the tune of 50 grand plus I lost my new 3rd member.
I borrowed the money from Guido and paying it back set me behind
about a year.
This company knows their business but honestly who builds ratios specifically for LSR.
The engineer I'm dealing with asked me what my requirements are and I think that was fair.
He wants to give me exactly what I want but I don't have the knowledge or experience.
The reared is set up with what I have and to go back to the 9" now would just kill the project.
I'm not George Poteet and probably have less money than the guy who cleans the salt off his tires.
If I told you what kind of budget I have you'd say I was full of BS. I'll figure this out but thanks for
the input.
Mike, it might be a good idea to run the car with the closest gearing that you can get cheap.  Then, based on observed performance, change the gearing.
desotoman
Quote from: tauruck on December 28, 2018, 12:45:05 AM
Here's my problem.
I have a GM rear end and the ratio is 2.44:1 but I think it's a 7.5" as opposed to an 8".
Please correct me if I don't know what the heck I'm talking about.
I'm stubborn and I want what I want, period. I want a 2:1 ratio.
Mike,
You need to talk to Sparky as he knows all about GM 7.5 rear ends. And if I remember they made a 2.14 Ring and pinion for those units. If it were me I would use one of those ratios first, then see if I really need a 2.0 ring and pinion. Just my 2 cents.
Mike  That is 7%   8000 vs 7500
Quote from: desotoman on December 29, 2018, 09:58:26 AM
Here's my problem.
Mike,
Sparky and I did discuss the 2.14 Tom. Maybe I need to revisit that. Thanks man. :cheers: :cheers: :cheers:
What should the correct ratio be for a crankshaft driven water pump pulley setup
in an LSR application with max RPM being 8500?. I'm thinking the stock setup will
create cavitation?.
Been doing some work but everything is sub standard. Dumped all the junk.
Lost my mojo.  :evil: :evil: :evil
Reset, try again.
No sweat Mike... been having that issue myself.... I know we will come thru it...  :cheers:
Just be careful... don't try this at home.... stainless tailing grabbed the lathe chuck and then gathered a few more.... those things are a little sharp... got me before I could move....
sprung a pretty good leak .... no worries... it musta been extra, 5 stitches and all is well
alternators and water pumps do not like over 5000. rpm
jacksoni
Quote from: SPARKY on January 18, 2019, 07:48:17 PM
I am going to respectfully disagree about alternators. Most run stock at 2-3x crank speed. Just look at the pulleys. Powermaster says for Delco style max rpm 18000, for Denso style 20000. "one wire" alternators don't start charging until 25-2800 at start up generally speaking.
G/GCC- 194.580 2025
Quote from: Stainless1 on January 18, 2019, 07:38:20 PM
Not cool. But it could have been a fly cutter (if that's the correct term?) on the mill.
Sorry you got hurt. The Claret must have been everywhere?.
Heal up brother. :cheers:
I'm either whining or looking for advice.
I need to stop whining. I have it good.
I've got this Fueltech system (FT 350 I think) and I was thinking
of mounting it into that Carbon Fibre F1 type steering wheel I built.
I can't think of anywhere else to mount it?. The steering has a quick release
so the tech guys can place it anywhere within reason. Any advice?. Thanks.
