Breaking Wind
Started by revolutionary, March 17, 2014, 06:53:44 AM
revolutionary
Breaking Wind #9614
  ECTA Record AA/BGALT 214.8
revolutionary
Also finally set the front and rear suspension.
4 link is set 65.5 inches out and 6.125" above ground.
Front is set with 0.75 deg neg camber, 14 deg KPI, +9.5 deg caster, bump steer -0.001"/+.010" at 1" drop/1" compression, 1" body rake across the length of wheelbase, 1 deg neg camber gain at 1" droop, 0 deg camber change at 1" compression.
Breaking Wind #9614
37str
Looking at your pictures, is it legal to build a spoiler on to a stock spoiler. I would think you would have to do one or the other. Does not look legal to me
revolutionary
Spoiler meets all the rules in the book. 10 in chord at the centerline. It is mounted to the factory hatch lid.
Breaking Wind #9614
revolutionary
Wrapped the headers
This is the orientation of the clutch slave
First time in the sun in a while. hosing out the trash and doing touch up paint. Finished all the fire system plumbing, one on each side of the pan, one by my feet and one by my head facing down. finished intercooler plumbing. Still need to finish radiator plumbing but that is the red hose in the pic. Two of those will run through the 4" steel tube running through cockpit.
Breaking Wind #9614
revolutionary
Time to put in the spaghetti. Thanks to Painless Wiring and to DIY Autotune for the support!!!!
IQ3 dash
Barfing some wires
Hooking up sensors
Weatherpak everything...
Life (electrical at least)
Breaking Wind #9614
revolutionary
Breaking Wind #9614
tauruck
Scary!!!!!!. 8-) 8-) 8-) 8-)
javajoe79
Looking good Daryl. I've been busy and haven't checked in here in a while.
615-210-1605
revolutionary
Only took a little while to get to this point... Got her fired up for the first time this weekend!
https://youtu.be/96rxpu5AWx4
Breaking Wind #9614
tauruck
I agree with Joe. Awesome amount of work in there.
Way to go Daryl. :cheers: :cheers: :cheers: :cheers: :cheers: :cheers:
revolutionary
Looking more like a car
Breaking Wind #9614
looks great PM sent about the clutch
Daryl;
Very nice build!
In the last photo, it looks like there is a gap between the front of the spoiler and the trunk lid. If so, this will be interpreted as a "wing" since air  can flow over both the top and bottom of the surface. This was pointed out to me when I posted pictures of my spoiler. I blocked the underside air flow to solve that rule interpretation.
revolutionary
Manta,
I see what you are talking about. It is just a reflection though. The aluminum spoiler goes all the way and connects completely with the decklid.
thanks!
Breaking Wind #9614
