Breaking Wind
Started by revolutionary, March 17, 2014, 06:53:44 AM
javajoe79
Today's progress..... I added the angles to the frame behind the firewall and I got the front clip stuck on there where it goes. Then I trimmed the firewall to fit back on. Next I will connect the forward part of the front clip to the roll cage with some 1.625" tubing.
615-210-1605
javajoe79
615-210-1605
tauruck
dw230
You sir, are filling your digital film roll up with all the photos. Keep it up.
lsrjunkie
I agree! Looks awesome Joe. Very well thought out, and the attention to detail is outstanding! Keep it coming man!  :cheers:
revolutionary
front clip and body - I pronounce you married
Breaking Wind #9614
  ECTA Record AA/BGALT 214.8
javajoe79
615-210-1605
DND
Like Rex says very nice, are you designing in places to stick in a ton of lead or more to keep her planted so you can use all that new power?
You don't want the rear spoiler getting to the light's ahead of the pilot!!
G Don
javajoe79
Quote from: DND on April 24, 2014, 04:43:44 PM
G Don
Yes the main frame rails along the floor of the cockpit are open on the back side. We will be making bricks that fit up in there and bolt on caps for the rails. It will give us roughly 10' worth of 2"x4" tubing to fill with lead. Not to mention the 1/4" plate floor and other spots to fill with lead.
615-210-1605
javajoe79
Little bit of cage progress. Haven't done much lately but this. Got word from SCTA about body stretch and wheelbase so we are good to go with that.
615-210-1605
Tman
My first reply on this thread, I like how you have many tubes notched and tied together!
javajoe79
#57
thanks T!
More progress lately. I mostly finished the mid plate and reinstalled the drivetrain into it's final position. Next up will be front engine mounts. We were originally talking about two plate style mounts on the front of the block, down low but after thinking it over real well I think using the stock mounting holes on the block will package best and free up room up front where things are likely to get pretty cramped.
615-210-1605
javajoe79
615-210-1605
jl222
#59
  Looks like the engine could be set back closer to the firewall. We set ours back as far as we could and still pull the heads straight off the studs.
  We also ran bars from bottom to top on cross tubes like yours behind firewall and mounted to engine plate with 3- 5/8 bolts on each side thru upright bars with steel tubing welded inside for bolts to pass through.
 More weight on rear tires :-D
