G/F class lakester in Wichita, Kansas
Started by ggl205, January 02, 2016, 07:37:55 AM
Podunk
MM,
Hope you got um all out before you fired that muther up.
ggl205
Building a mold-less body with ABS is something new to us so a few unexpected problems were expected. Everything was going well until I sprayed two coats of EVA mold release. First coat was a light tack and the second much heavier. Prior to using EVA, I asked the supplier if it would react negatively with ABS. He said no problem (where have you heard that before?) so we proceeded. Well, EVA does react mildly to ABS in that it softens and swells it some. After just two coats, large distortions began forming and those of us involved in this project were noticeably bummed. Now what do we do? After a period of discussion, we decided to be good Boy Scouts and do nothing until the next day. It was a cool night, around 40 degrees, and I hoped that would help shrink these distortions out of the ABS.  Cool air or just more drying time, all distortions were gone by morning and our positive countenance returned.
I post this in case others try this method. I must say that when observing these distortions, we darn near tore everything apart. A little patience went a long, long way and returned the project to normal. Tomorrow we are supposed to experience 70 degrees and a good day to lay up fiberglass. Now, I hope epoxy resin plays nice with an EVA coated ABS.
WOODY@DDLLC
John, this just confirms my mantra that everything has consequences!  :-o :-D
We are all itching with anticipation for your fiberglass lay up!  :cheers:
Speed Limit 1000
#123
John, I have never used EVA but PVA, or polyvinyl alcohol, works well. I have had good luck using aluminum foil over foam to get a smoother surface and a clean release.  Your build is looking really nice. I hope we have good salt this year for racing :cheers:
http://www.fibreglast.com/product/PVA_Release_Film_13/Mold_Releases
Johnboy
ggl205
Woody:
Hah! We will literally be itching to get this glass work done.
Johnboy:
Thank you for the kind comments. Building this body has been an adventure into the unknown. So far, so good but we ain't done yet. BTW, fiberglass materials have gotten expensive!.
Sometimes it helps to make something goofy, like a flower pot,to see how the system works before you try something important.
robfrey
We used PLA printed molds on our fairings between the wheel pants and wing and fuselage and wing.
We covered them with PVA then two layers of 7781 glass w epoxy resin at 45° to each other.
We then popped them off the PLA, rinsed the any residue of PLA off the inside, scuffed up inside and layed up a couple of more layers of 7781 for strength.
We also kept the stiffening layers away from the edges a bit so that the glass was very thin where it attached to the wing making body work a breeze.
We also had to super glue our PLA pieces together as our printer was 12 x 12 x 5.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
ggl205
#127
Quote from: robfrey on February 19, 2017, 08:25:28 PM
We took a similar approach with our nose. The printer available to us mandated doing it in six sections, then super glue them together. We are using three laminations of Hexcel 7500 for strength and 7781 for finish. I had planned on using 120 for finishing but my supplier had a near full roll of 7781 he wanted to get rid of at a knock down price. A little heavier than 120 but at $2 per yard, I could not pass on that.
I like how you oriented laminations at 45 degrees. Very strong structure that way and we my very well do the same. This is my first experience at fiberglass so keep your fingers crossed.
looks and sounds way more than beginners luck to me-- this little baby is going to be sexy
ggl205
I sure hope it all turns out right, Sparky. We managed to get one layup done today but ambient wasn't quite as warm as forecast. Much of the day was 55 degrees. 4:1 mix for epoxy and hardener was spec but not enough for 55 degree air. It did give more time to saturate mat and squeegee out excess resin, however.
It was decided to let this layer harden before moving on. After three layers is completed, we will mix a batch of microspheres, fill small cavities, then sand. The final layup will be a finishing layer. Lots more work to be done but not sure I will get this warm weather for very much longer.
ggl205
Well, the first layup was completed on Monday and awaiting the slow cure time for epoxy resin. Next layup will be on the next 70+ day we get. Attached is a new 3D rendering of what the car will look like. Those with sharp eyes can see the exhaust bubble is backward. That will be fixed soon.
salt27
John, If the 3D rendering is accurate there may be a forward visibility issue.
At least that's what I see when making a strait line from where I think the eye port of the helmet would be in relation to the front cowling.
Hope I'm wrong.
Love the name "Kansas Twister"   :cheers:
Making the fin taller and extended more to the rear may help your high-speed stability, John.
We had some glass that would not quite cure.  Months later we put it outside and let some summer heat and UV work on it after 3 days it no longer "seemed" green
ggl205
Quote from: salt27 on February 22, 2017, 08:34:59 AM
Hope I'm wrong.
You guys really do have sharp eyes (lol). Don, visibility may be a problem as is. I jumped in the car early on in the build process and thought the same thing. If this proves true, we will extend the polycarbonate forward until we get it right.
