9" Ford
Started by azgearhed, February 23, 2016, 01:59:01 PM
azgearhed
Wanted-9" Ford 2.47 gear set -Tim 602-980-2924
BC Racing 1979 Z-28
AA/CBGC Record 251.802 Speed Week 2012
AA/CBGALT Record 255.382 Speed Week 2013
AA/CBGC Record 226.104 El Mirage Sept 2015
AA/CBFALT Record 227.954 El Mirage June 2016
AA/CBGC Record 267.878 Speed Week 2018
AA/CBGALT Record 236.458 El Mirage Nov 2016
It's a lot of work to have fun...
John Burk
There is a set on ebay .
runt13
i may have one? let me look a friend of mine wanted to build a rat rod and dropped off a bunch of ford stuff a few years back. ill check tonite
RUNT ''13''
who would have guessed it would take so long to go so fast for such a short time?
2012 Wilmington mile
April meet,
p/pp-1350/4 record, 132.601mph
September meet,
p/pp-1350/4 record 139.915mph [bump]
p/pp-1650/4 record 142.364 mph
p/pp-2000/4 record 140.009 mph
p/pp-3000/4 record 144.511 mph
2013 Wilmington mile
July meet,
m/pg-1650/4 record 137.278
m/pg-2000/4 record 136.695
Sept meet,
p/pp-1350/4 record 141.1986 [bump]
2014  Wilmington mile
May meet
p/pp-1340/4 record 142.5855 [bump]
Bob Drury
  If you run across any 73 or 74 Lincoln, Big Ford or Merc sedan or station wagon, they should have one .  Think oil embargo/waiting in gas lines (if you are old like me)
Bob Drury
RichFox
I had a '78 F150 that came with 2:47s
Ron Gibson
Most 77 and 78 Thunderbirds and Cougars with 351/400M engines had 2.47s in them. That oil thing again.
Ron
runt13
The one that lives behind my shop is out of a 66 or 67 mustang, ratio unknown. However it is complete as in [9'' ford rear with axels and center...no brakes.
being a bike guy, where would the ratio be on the rear!
RUNT ''13''
April meet,
September meet,
July meet,
Sept meet,
May meet
bill78
Have you tried Pro Gear in San Diego? 855 571-1158
RidgeRunner
Runt
     There might be a little metal tag about 1" by 3"  held onto the outside of the center section by one of the nuts along the lower front.  Some had the actual ratio stamped in them, some a letter code. After almost 50 years the odds of it being there, legible, and still applying to whats inside aren't that great.  Only way to know for sure is pull the chunk/pumpkin, count the teeth on the ring and pinion gears, then divide.
thundersalt
what do you have for trade? :wink:
916 REMR
El Mirage 200 MPH Club
ronnieroadster
RansomT
#12
Quote from: runt13 on February 28, 2016, 11:44:54 AM
RUNT ''13''
(if you turn one drum and they both sides turn together) Turn one drum 360 degrees and see how many times the yoke turns.
(if you turn one drum and the other side pretty much stays put) Turn one drum 720 degrees and see how many times the yoke turns    :-)
geardaddy
I have a couple of 2.47  third members and also some 9 inch 2.50 gears.....612-309-3999.....612-309-3999  I am up VERY late..
salt
I have 2.30 for a 9 inch.
Who Has More Fun?
