Quickchange horse power drain
Started by ronnieroadster, December 06, 2016, 01:18:21 PM
Frank06 said "No way it is 98% efficient.... chain drive isn't even that good." Actually roller chain is really only 90 to 92% efficient the best drive "chain style" drive are the HVO belt drives which are over 98% efficient.  Sorry for the hi-jack now back to quick change question.
ronnieroadster
The latest issue of Hot Rod Mag has an interesting article about the Ford 9 inch its not anything helpful for my question but still good reading.
They quoted an efficiency number in that article.
floydjer
AMC products from 1982-87 used a 2.21 gear set. Maybe somewhere out in industrial gear-land there is a bevel gear set of 1.5-1 that a clever person with a mill and lathe (No, I am not volunteering) Could machine a case that would mount change gears to get you down to the ratio you want...Double gear reduction working in your favor.
desotoman
#34
Quote from: floydjer on December 23, 2016, 06:06:13 AM
Has already been done by one person I know of, his name was George Parker (RIP), he made a quickchange back in the early 1990's and you could get it with a 1.5-1 or 1-1 ring and pinion.
Mel Swain (Swain Bros-Helash-Hoover) used the unit in his Blown Fuel Modified Roadster, in 1994 with a 1-1 ring and pinion. They still hold the top 3 engine class records at El Mirage in BFMR some 20 plus years later.
floydjer
See...Every now and then I have a lucid thought...............
Ron Gibson
IIRC John MacKichan used a 1.5-1 bevel gear in a V8 QC center section in his and Tim's liner. He machined everything but the center housing (side bells,etc.) to make it work. I think with the right spur gears they could get .63-1 final drive ratio. Huge hours involved to get it done.
Ron
When Mickey Thompson first considered "challenging" (pun intended) Cobb's record in late '58, the first item he envisioned was single-spur-gear sets (1:2) at each wheel, to obviate the need for pinion shafts/bearing to spin about 13,000 RPM. These four gearsets were actually the very first pieces fabricated. Admittedly, this approach could possibly require reverse-rotation engine(s)- but it served very well in the Challenger 'liner (since 2 of the 4 engines needed reverse-rotation anyway). Just something to keep in mind...
