mod rdstr fairing
Started by russ jensen, March 07, 2007, 09:02:15 PM
russ jensen
Quote from: desotoman on March 13, 2007, 03:43:01 PM
Russ,
Here are a couple more.
that is a nice looking fairing. if its not considered to be contoured- great- I can do that! thanks for great pics..russ
speed is expensive-how fast do you want to go?-to soon old & to late smart.
russ jensen
Quote from: Glen on March 13, 2007, 10:17:27 AM
Set a record and the protest cops arrive to scrutinize for legality. :?
Is that sort of like the circling buzzards mentioned earlier?
russ jensen
Quote from: Glen on March 13, 2007, 04:42:04 PM
Jack, as I understand it the dimensions to make it legal were taken off the old Black Widow I drove that is in Jim L's collection. It was original all around. I heard they made templates or took all of the measurement's off it.
GB
Anybody have templates for my 23 Oakland? Its wider than a T but I don't care -doubt if there are many left- I saw one  @  Murdo SD measum in the wing that burned up in 60 0r 61, and they left as fire left it. Mine has been out in weather since before ww11- still has fair amount of "true blue " paint on it.
jimmy six
Russ It will be up to you to supply specifications for the body your are choosing to use. They should be from original style manuals. If one of the "stock" vehicles can be found I would go to it and not only record the measurements but have quality pictures of your taking down the numbers. The SCTA can deam all records set by you on hold until the proof information comes in from you. It's your decision to use a "non-Ford or traditional" vehicle. Doing this puts the burden on you.
I don't discourage this. I only point it out so you know what will be happening.  Everything should be kept with the log book.
When I rebuilt my American Austin for the 1st time, of many rule changes, I brought a stock hood along with the lengthen hood I had on the roadster to a board meeting because of a protest. (they thought they had me that time).
Good luck. J.D.
desotoman
Russ,
  Glad I could help you.   :-)
russ jensen
Quote from: jimmy six on March 14, 2007, 09:55:32 AM
Good luck. J.D.
Thanks for the heads up on something that wasn't on my radar screen. Since I have only seen 1 other-that is sure to be gone -as was a bucket of rust from fire -I don't see how I could prove- It's 34" wide @ firewall-my essex is 34 1/2 and 31 A is aprox 35 depending if chrome beauty strip is included-which has to be wider than 23 T- therefore no aero advantage{ probably wouldn't matter to circling buzzards?}If body is obviously not been altered- cept to replace rotten wood. one would think that would be enough- guess not-w/all parts I have collected ;it would be just as easy to build lakester- however that is more like building airplane on wheels- I wanted to avoid aero as much as possible-besides - I don't like visions of rolling pencils.This whole deal is beginning to look like other adventures I got myself into- everybody is happy to see you while the shake out is taking place- then when you start to kick ass they suddenly try to figure a way to take you out.
It may be a little early to get upset about this.
JD is only trying to show you easy ways to substantiate your ride.  He's had to do it himself.  And successfully.  before you modify the body into its race car mode, take some pictures with measurements visible -- maybe even with the old wood still in place.  Are you leaving the wood in -- or are you replacing it with metal reinforcement?
The whole idea is to show its stock configuration.  Being wider than an Essex or '23 T is not the point.  Being creative and using something different is great.  But after you've straightened it all out, patched it, reinforced it, and smoothed it, and painted it, it may be hard to see it's still stock.  And the inspectors (and potential protestors) are not familiar with the dozens and dozens of makes of roadsters.  And when you start kicking ass (which is not exactly easy in MR classes), it'll be easier to show them what you started with.
Take his advice and join the fun.
JackD
Somewhere on the Internet will be an Essex club that can provide you with all the factory original documents including dimensions to keep the buzzards at bay and maybe even for the Ford.
REMARKABLE
jimmy six
Stan and Jack D are right. Club info is a good approach. If you have a dream do it, or be like the rest driving Fords with belly button engines...Good Luck
GeneF
Quote from: JackD on March 16, 2007, 11:08:42 AM
REMARKABLE
Just don't tell them your hacking it up into a race car, some of those restorer guys can get pretty testy and you might get some bogus dims. along with some hate mail.  :-)
JackD
I put some 32 Ford front fenders backwards over the rear wheels of my lakester / streamliner once and the gathering mob of resto racers was looking for a tree at El Mirage to hang me.
Just as they were about to snatch me they figured out the fenders were fibreglass and they all became new best friends.
Basketcase took a couple of pictures and put them in Hot Rod.
That was close. :wink:
russ jensen
REMARKABLE
No problem w/ Essex - have a spare cept its a 3 window coupe w/ sucuide doors- the roadster is Oakland- wood is all rotted out and the body panels were nailed to it - it's a bunch or body panels - a couple of doors  & firewall/cowel unit- was going to weld it altogether as a 1 piece unit and skip any wood- bottom of panels are pretty rotten so was going to sandblast & lay epox & kevlar inside to hold together- have looked on net found  Oakland/Pontiac club -were only interested on selling memberships.Guess there aren't any trees @ bville, but this one is pretty far gone for anything but race car. therefore I should be safer from a necktie party than Jack.
russ jensen
#42
Quote from: Stan Back link=topic=2180.msg25463#msg25463 date=1174062665
/quote]Goes without saying- If my engine has got it it will :if not it will fall into cat  like Jack says - theoretical calculations lead to theoretical results- won't know till it is put to test- but roadster would be better test of eng than lakester- and I like old iron.-like has been said"just glad to be here" will ad- just glad to try.
