JAL AKA JL222
  Steve Moody's AMS shop flow tested injectors and most were bad. New injectors at Post Office to be picked up.
Closed today, They used to deliver parcels to my community mailbox which has large boxes for parcels but now I have to drive 20 miles to pick up.
Troy took gas tank out and cleaned it and fuel lines, a few particles but nothing filter would not have trapped although we had a 40-micron filter which we found out should be a 10-micron.
Some paint touch up were tank sits up and reinstall tank and new injectors next weekend.
fingers crossed that new injectors fix problem. If not single finger: laugh:
71GSSDemon
Quote from: JAL AKA JL222 on February 17, 2025, 01:26:06 PM
Hopefully that solves your issues.  Fingers crossed.
JAL AKA JL222
#2687
  installed new injectors and filter. No start up? No spark, called our buddy Donny Cummins and Holly rep and he troubleshot Troy to get spark.
Fired up ran great but a little rich.
Ready for May El Mirage and will run A blown fuel altered instead of gas altered but still on gas.
  Record 258+
. . . is more better a little rich than it is a little lean.
JAL AKA JL222
Water in headers was found to be a small hole in exhaust ports due to porting. Added 3 bottles of Bars Leak engine sealant, problem solved.
  We ran engine to get hot enough to set final valve lash running up to 3000+  and when checking computer read out driver side 20 to 23 AFR. Plugs looked fouled which is normal after idle so ordered new oxygen sensors.
Been having problems with white growth on the magnesium valve covers which in the past could be solved with WD40 but not anymore so their being powder coated. A little tough to do on mag.
JAL AKA JL222
Valve covers powder coated blue, sort of matches hose fittings. Left side oxygen sensor white, right-side black, sprayed with brake clean and seamed to help as air fuel ratios back to normal.
New sensors back ordered to April 24.
JAL AKA JL222
#2691
Well...El Mirage was up then down. We ran A blown fuel altered with gas with hopes of going over the 258+ record.
troy ran 246 on a conservative throttle for him. Looking at the data we figured shifting at 7000 rpm instead of 6800 would give 2 more Lbs of boost in high gear and more mph. 6800 in 3rd to 4th rpm drops to 5100 and a loss of 10lbs of boost So higher revs more boost and speed in 3rd'
  Then the F ups began. Sun 2nd run Troy takes off but not running right, turn out and back to pits, forgot to take intake cover off !!  Change to warm up plugs and warm engine install race plugs. 3rd run Troy take off fairly good start but another turn out and back to the pits. Someone and I know who forgot to put plug wires on left bank  :?  Hey sounded pretty good at start up on 4 cyls :-P ,back to pits ,left side plugs like new [ never run ]  Right side fouled. Installed new plugs on right side.
   4th run 195 mph trouble taking throttle. Time to pack up.
  We failed inspection because of seat belts out of date [ thought we had another year] but another racer had a new set :cheers: We also had, our Fire bottles inspected by Mike Kilger and FIRE FOX in the pits.
Mike Spaceck (spl) and SCTA Inspectors, what a great bunch of guys they came to our pits twice in the dark to check our seat belt install and give us the final inspection sign off :cheers:
sion
desotoman
#2692
Sunday night I was fast forwarding the Sunday video, and when I saw your car in the staging lanes I waited to see your run. While watching I noticed what looked like a Moroso plug in the air intake? Then I said to myself I must be mistaken. When Troy turned out I thought maybe I did see a plug in the intake. Thanks for the clarification. Sorry it happened.
PS. The name on the plug was Harwood, sorry for any confusion.
JAL AKA JL222
We switched from two 12-volt batteries to two 16 volt. Our ECU requires 12 volt minimum and data log shows volts dropping to mid 11. Engine spins and starts much faster. Hopefully 16 volts will help the power problem.
Engine sounds great and cyl compression check was better than ever.
JAL AKA JL222
Quote from: JAL AKA JL222 on May 26, 2025, 06:45:31 PM
  Data log showed 15.7 volts at last startup, good news there.
  The problem with 16-volt batteries is Calif prohibits the sale of 16-volt chargers or tenders :x
   Found that 16-volt batteries can be charged with a 24-volt charger which I have. So gotta keep charged.
deepindebt
We also switched to 16 volt, was able to get our XS Power charger through Amazon and shipped to my Ca address.
327,B/GR
JAL AKA JL222
Quote from: deepindebt on May 27, 2025, 02:38:42 PM
  Found and ordered. Thanks
JAL AKA JL222
#2697
 I ordered 2 8-inch-deep chute packs as ours are 7 inch and require me, a body builder and Sasquatch to pack, both on our crew :-P
  Looking for ways to be faster and easier.
deepindebt
327,B/GR
JAL AKA JL222
Quote from: deepindebt on June 03, 2025, 12:43:47 PM
Good idea, where from?
  Good Vibrations Motorsports
