Anti-corrosion finish for copper intercooler?
Started by Dakin Engineering, January 01, 2008, 06:12:24 PM
Dakin Engineering
Does a wrinkle paint finish produce enough surface area to matter?
Happy New Year!
Sam
Turbo Sportsters since '97
JackD
The  insulation provided by the paint exceeds the presumed benefit of the wrinkle finish.
Try GUN COAT.
It goes on thin, almost like ink , and has to be cured in an oven.
Plating is another option.
Dakin Engineering
Looks nice, how about soldering some fins to those tubes?
Dakin Engineering
It's for a water/air and my best guess is that direct ice/salt packing will give the best IAT differential for 3 minutes.
Love to see other examples,
Sam
Dakin Engineering
Jack,
  After due consideration, I'm gonna paint the copper with anti-seize and wipe it down.
Thankee,
Sam
Dynoroom
Will you be monitoring the air in and out temps? I'd like to see how well you do with this if you don't mind.
Thanks
Dakin Engineering
Intake air temp and MAP, O2 front cylinder. K thermocouples on both pipes.
A box that  knows what to do with it. :roll:
And a prayer........
San
Why are you going to paint it at all!?  If it is going to be in water the direct contact of the water to the copper is best. Any coating will reduce the rate of heat transfer.
Dakin Engineering
During my testing with various liquids, brine being one of them, it developed quite a bit of surface corrosion. Polishing it out again got me thinking.
Silver plating would improve heat sinking, but still corrode. Not to mention the expense. (I've got a roll of silver solder and a propane bottle invested so far.)
I'm looking for the simplist, cheapest way to keep corrosion away.
Does gun blu work on copper?
Sam
angryyouth
Look into a product called Incralac, Its a sealer for bronze and copper and it doesn't brake down like normal sealers/paints. I'm not sure what reduction in thermal transfer it might cause, but I cant imagine it would be much. otherwise just let it patina.
-A
panic
IIRC Birchwood Casey used to make a copper & brass blackening product for gun hardware - try Brownell's etc.
Dakin Engineering
Thar she blows! Brass Black.
Thankee, sirs
Sam
Sam,
If you are going to use brine maybe you should put some sort of "scrafical" anode into the tank so that the electrolsis is between the scrafical anode not your copper cooler. I think that mag works for this but I am sure some one that actually knows will post.
Randy Williams
Sam,
               call Finish Line Coatings they apply Thermal Dispersants. Might work.
                      http://www.finishlinecoatings.com/
