BB Bonneville Bugeye
Started by hotschue, February 19, 2008, 07:10:38 AM
hotschue
Started new project will post progress from time to time.  Thanks to Sum for the inspiration and my friends who helped get the project moving.  Objective is Maxton for sure, Bonneville a stretch (2008). Will post photo's from time to time, class Modified Sports, engine yet to be determined.
221.559 D/CGC '03
182.144 G/GMS 2019
JackD
Well you are past the hard part.
A couple of "all nighters", and you are set. :wink:
Is that a cowl for a Sprite I see?
I'm thinking a Speedwell Sebring front clip might be legal in your class.
hotschue
Yes it is, I will be using a modified cowl and stock rear clip.  Cowl forward will be fabricated aluminium nose and side panels.
221.559 D/CGC '03
182.144 G/GMS 2019
hotschue
Today is a big day.  Main frame rails cut and fit ready to weld.  First fit of the rear body section, starting to look like a car.  Will begin design of roll cage, narrow the rear and build the front axle.....Sounds easy enough!!!!
221.559 D/CGC '03
182.144 G/GMS 2019
Progress!
You thinking SBC, or just using it to dummy up for location?
This could be very frightening when you're done.
Quote from: hotschue on April 02, 2008, 03:03:09 PM
Looks good!!  Don't let anyone give you a hard time about the "flat" wooden tires/wheels like they did about my wood frame  8-).  I like the build table,
isiahstites
Quote from: Sumner on April 02, 2008, 04:37:37 PM
Car looks good and I love the build table..........oh, nice wheels!!
hotschue
The table is great, don't have to bend over to work on it.  SBC power, class somewhere between AA and D.  Had to take the rear tires off to set the body on.  I guess I'll have to down size'em with a router.
221.559 D/CGC '03
182.144 G/GMS 2019
hotschue
 Have added front and rear frame sections and all suspension mounts.  Started going vertical today hope to have roll cage pretty well under way by next week.  Material arrived for the bodywork, wishful thinking, maybe in 2 or 3 weeks.  Want to make this a roller as some as possible.  Pic as of today......
221.559 D/CGC '03
182.144 G/GMS 2019
hotschue
Finished welding the main frame, the chassis is back on the table at ride height. Next week the roll cage and suspension.  It's coming together.  I fitted a dragster seat and can finally sit in the car. Will have BB sitting on its wheels shortly.......
221.559 D/CGC '03
182.144 G/GMS 2019
Nice work - curious as to your front suspension, but I'll wait and see.
It's easy to lose perspective on this with the cowl and rear section removed.  How long's your wheelbase?
Cheers!
Carl Johansson
Nice split window!
Carl Johansson
Carl Johansson
Auberry Ca
dwarner
Why are you so high out of the car?
hotschue
Wheelbase is 129 inches.  The shoulder hoop is 4 inches below the body shell.  Less than 12" of roll bar will be outside the body lines.  Sitting in the car the line of sight will be the top of the cowl.  Body height is 25 inches + 4 inches ground clearance.
221.559 D/CGC '03
182.144 G/GMS 2019
