Nose job
Started by Jonny Hotnuts, March 08, 2008, 02:56:44 PM
Jonny Hotnuts
Last pic of the car with the old nose:
Me with Sawsall
Almost off
Pop with nose off car
Next week I will have a roller.
jonny_hotnuts@hotmail.com
*Andres Segovia
ol38y
JH, you look like you're havin too much fun with that sawzall... :evil:
Look forward to seeing the rest of your work... :-D
Larry Cason
2010 BUB 1350 M-PG record
Geo
Jonny,
Which end are you keeping?
Speaking of keeping... keep your friend away from my car!
Geo
Jonny Hotnuts
Here is the result of last weekend.
I had a lesson in fish-mouthing bar ends (first time)....I had to hand shape them with an angle grinder, and this sucks....way to much work. I will be buying a pipe notcher in the future. I tacked some plate casters on the front so I could have a roller so its a bit nose pitched up.
I have a few more bars installed sense this pic was taken, and have some lateral support bars to go, but this is the basic idea. I need to finish welding up the pieces.....no rest for me.
In this pic you can see the basic placement of the wheels @ 27" spread and 130" base.
*Andres Segovia
landracing
What's with the residual on the weld spots??? is that some type of oxidation from a dirty metal?
Mig or tig??
Jon
It almost appears to be zinc. If so the metal is electrical conduit and not up to the task. Please check. If the deposit is a soft white and there appeared to be almost a film of white coming off it's zinc plating. It will contaminate the weld and can make a person feel rather flu like.
As for prepping the tubing, if you make two cuts at say 45 degrees so you form a point, then rotate the tube 90 degrees you will see that its almost prepped. Play with the angles and don't cut quite to the center and the grinding will become minimal.
Mugs914
I doubt this is new to anyone, but I use a hole saw set up in the vert mill to notch tubes. Its easy to set up any angle or offset and if you're really careful (lucky) there is no grinding at all. 8-)
Of course if you don't have a mill handy this is pretty useless info, I suppose... :oops:
Cheers,
Cheers,
Mike Mulligan
Mulligan Racing Development
Vista, Ca.
760.945.5991
Mugsxr4@pacbell.net
How's all that tubing attached to the rest of the car?  It's a unibody, right?
Jonny Hotnuts
The deposits you see are because I am using a flux core mig wire without shielding gas, it does the same thing on all steel I weld with it. The welds look fairly decent up close, I will post a pic soon and can assure you that it is not conduit; it is 1.5X .95 mild.
The car is a unibody-frame hybrid. I have huge support bars (2x4x1/4") integrated into the frame tunnels, they are also a mount for the primary hoop of the cage, connect to a cradle that supports the engine, and where the tubes of the nose attach under the car. The top of the nose section was integrated into a section of the roll cage but will have additionally pieces added soon.
*Andres Segovia
Jonny Hotnuts
close up pic of welds using flux core wire (cleaned up)
They are ugly but I have never claimed to be a good welder!
*Andres Segovia
Jonny Hotnuts
#10
I decided that I would try shielding gas; I have always tried to avoid gas because I need portability for occasional work projects.....lets say I had some advice!
The guy at the welding shop sold me a tank (75X25 argon-Co2) and a spool. Needless to say I now kick myself in the azz....makes a huge difference!
I now get it....all the problems I had with inconsistant performance have been answered!
*Andres Segovia
Jonny:
Your welds look good up close. The thing you'll notice with the gas mix is how much cleaner your welds are with a lot less spatter. Keep up the good work.
I don't regret mentioning galvanized material as it may save someone else. I've never suffered the results but I have talked to others who have and I guess "zinc chills" are no fun.
RidgeRunner
     FWIW, over thirty years ago I halved an old galvanized hot water tank with a cutting torch for a neighbor who wanted a couple of troughs for his pigs to feed from.  Had heard stories of messing with galvanized so did it outside the shop door staying on the windward side with a gentle breeze blowing.  Still wound up with a severe headache that lasted beyond the following day.  Have been super cautious with a torch [or arc welder] around galvanized and haven't cut any since.
     Zinc might be benificial in other forms but is BAD stuff to breath when burned.  A subject well worth bringing up Pete.
     Jonny:  I'm no expert but I've seen a lot of worse looking welds over the years.  Keep the questions and build pictures coming, a lot of us lurkers out here learning from both.
                   Ed Purinton
Jonny Hotnuts
THE NEW MOTOR IS HERE!!!!!!
(not really anything to do with the nose but.......)
1507cc
APE Billet crank 5mm (APE)
Carillo H beam rods
Millenium cylinder +30
Wiseco high comp pistons
Ward big valve head
445/443 Megacycle cams
Koenig billet pan
High volume oil pump
S2K injectors
1mm bigger T.B.s
APE Billet Clutch Basket
Billet starter gear
Billet output shaft
and a number of other stuff.......
The motor made 252 hp on bike on race gas. Funny thing is when I got into LSR I opted for small bore motors to save money. Lets just say for what I have in this motor I could of had one hell of a BB!
*Andres Segovia
Jonny Hotnuts
#14
Results of Saturday 22nd:
X in the bottom
Plate aluminum
Tank R&R
More stuff to go, waiting on steering shaft placement before mounting the water tank, pumps and regs..
I also milled the axle shaft but left it at my pops so no pics.
*Andres Segovia
