Saturday it is.  I'll update the spreadsheet tonight.
I have a lot of admiration for my friends in Oz - they're heading out to Gairdner with a car that's not running.  They'll have Stainless and Wayno hanging out - both good tank wrenches - so the deck tilts toward SOS's favor with that.  If they can make it happen, it will be like a Phoenix story.  I wish them that storyline, and I wish them nothing but the best of fortunes.
I - on the other hand - have taken an untested car to the salt before.  I will not do it again.  So desperate to avoid that situation am I, that I will actually go to ILLINOIS on a Saturday to avoid it.  :wink:
You guys make me jealous. Here I haven't even had breakfast yet and all I can think about is ale with brown foam and dollar tacos. I hope the meet up goes well.  :cheers: :cheers: :cheers:
Quote from: Peter Jack on March 08, 2018, 06:35:03 AM
Well, Mark's always said, "You can't say you've been drinking all day if you don't start in the morning!"  :wink:
Interested Observer
MM -- Regarding front end bump and camber behavior.
That the steering rod and lower A-arm may be parallel is not necessarily indicative of satisfactory performance.  Having been down this road before, analyzing this mathematically is not terribly difficult but does depend on having the locations of the various pivot points and axes of rotation identified in space.  While this avenue of investigation is of less importance at the moment in light of the engine work, if, at some convenient time you would like to do some measuring, some bump-steer curves could be generated.
I appreciate that.
I've been pretty diligent on working on the car itself the last few weeks - the intention is to continue the "divide and conquer" approach.
Not that the record is unclear - it was a little squirrely on the return run - but my thinking is that if I can get the front end optimized with what I have, it should be fine.
All of the front end components were new when installed, save the rack, which I chose because it was from a later model rubber bumper Midget that has a slightly slower turning ratio.  It's solid, so I'm not worried about it.
Moss has a shock valve upgrade which tightens up the lever shock for competition use.  Along with a new radiator and the offset bushings, they should be arriving on Monday.
What I AM thinking is that perhaps I might remove the shocks and possibly relocate the upper arm on the rotating shafts to assure that, when set at my ride height, the piston is operating in its optimal middle range.  Right now, it's not likely that that is the case.
I think the true wildcard in the chassis will be this.  I'm losing probably about 60 lbs in engine weight, and the engine and transmission are being relocated about 3" further aft in the chassis.  That's probably a great deal in a road racing Spridget - maybe not so much for an LSR car that, due to the cage and the battery location, is already likely to be a wee bit trunk heavy.
Won't know the weight distribution until it's all together.
kiwi belly tank
The poor mans fix to stiffen up Armstrong lever shocks way back in the 19th century was to up the oil viscosity. I never raced them, just built engines so I don't know what they put in them but it shouldn't be too hard to work it out.
They would also raise or lower the rack (can't remember which) to line up the inner tie rod joint on the upper to lower pivot line.
Quote from: kiwi belly tank on March 09, 2018, 08:37:12 AM
Heavier oil will milk a pair of leakers out for a couple years.  20 weight is what the factory recommends, but I used to run 50 straight in a worn-out set, and it helped.
19th century?  :?
"Queequeg, Ishmael, render the White Wale!  We must supply the colonists with shock absorber oil for the smooth operation of their horseless chariots!"
Actually, whale oil is cheaper than the stuff Moss sells.
:-D
forker
but harder to find, these days.
kiwi belly tank
Quote from: Milwaukee Midget on March 09, 2018, 09:56:36 AM
19th century?  :?
:-D
Just seems that long ago, see my age. :-P
forker
Actually, and displaying blissful ignorance again, I imagine that you wouldn't be agonising over use of glorified door-closers instead of something more conventional for damping if class rules didn't restrict.
Must the OE dampers be in use or merely present..?
I'm also good at spending someone else's money, so an upper link that attached to the lever-arm OE damper body at the OE damper location is attractive but presumably also out. In this class.
What about locations and lever lengths, though? If bump steer is genuinely what's going on rather than any other characteristics then equalisation of link length would seem obvious. So that's also out too, in this class.
If all that's true then the modified or adjustable kingpin trunnions must also be beyond the pale; but, they seem not to be that. So, there's a grey area.
Ah, I like those!
There's a fascinating you-tube log of two fellas in Shropshire (OK, in England) building an A-series Mini but with Celica GT4 powertrain and running gear. Yes, that's everything fabricated new except the roof, more or less.
Since there's complete bastardisation of the GT4 McP struts &c into all-new body structure and connived into a space that's half the size of the original Celica, geometry is an opportunity. There's a good illustration of a not-too-hard method to see bump steer, etc. Take a look at 'Project Binky' here; http://www.badobsessionmotorsport.co.uk/project-binky-episode-11/
That way, there'll be data.
F
ggl205
Oh my gosh, that was both funny and informative! I knew I was in for something good when the theme from Police Squad started playing. Great stuff.
Chris, I just sent you a PM.
fordboy628
Quote from: forker on March 09, 2018, 01:15:49 PM
F
Data . . . .  What's not to like? ?
:dhorse:  :dhorse:  :dhorse:
F/b
fordboy628
#6898
Renaming Suggestion . . . . . .
midget,
In the interest of . . . . . . keeping up interest, whilst my knee recuperates . . . . . .
I'm voting to rename this thread:      PROJECT PI          (Irrational, but well rounded . . . . . . .    :wink:)
Well, at least for March 14th anyway.
Hey,  Hey,  Hey . . . . .   it's still Friday where I'm at! !
And the bartender has cut me off . . . . :cry:
Humorco-ordinatorboy
WOODY@DDLLC
Quote from: fordboy628 on March 09, 2018, 07:11:14 PM
midget,
FB, this project has always been transcendental!  :-o :-D :cheers:
