fordboy628
Quote from: handyguy on April 09, 2018, 06:21:49 AM
   I have used allen head in tight spots ..
Yes.   A bit of an explanation is in order.     shcs is the abbreviation for Socket Head Cap Screws, the generic term for the Trademarked name of the Allen Co product:  the Allen cap screw.
So we are talking about the same thing.
It's like calling all facial tissues "Kleenex".
But, big suppliers like Grainger and McMaster-Carr have to use generic terms to describe non-branded products.     Or, deal with litigation . . . . . . .
I use the generic terms from habit, since if you specify a brand in a purchase order to a big supplier, you get zero parts and a note saying they don't carry your specified brand.    :-(
F/b
fordboy628
#7021
Quote from: Rex Schimmer on April 09, 2018, 11:18:21 AM
Mark,
Regarding your thread choice for the oil block, do you have a -10 "O" ring seal porting tool? Probably not but I'll bet you have a 1/2 NPT tap. I am not a real fan of pipe threads but a -10 port tool is probably $50+..
Looking good, the flywheel retention and location devices look good for at least 350HP+!
rex
Hi Rex,
I do not have a "unitized" -10 o-ring port tool, as you suspected.    I do have all the straight & NPT taps and counterbores though, so I could machine it in one setup per fitting, 3/4 separate operations, a pain in the butt.    Not sure which choice will be made at this point.    The carbide bladed -12 fuel injection rail drill/reamer/spotfacer combo tool set the shop back approx $220 . . . . . .  for occasional use . . . . . . .
I also dislike NPT threads on race engines.    I've seen too many "mechanics" "reef in" tapered fittings.    The result is a cracked casting, often not repairable.    Good judgment and the proper sealant prevents this situation.    But I have given up on my personal crusade to "cure" "stupid".    I'm sorry to report my efforts resulted in limited to no success, and only succeeded in raising my blood pressure.
In spite of the large size of the remote oil filter fitting block, because of the way the internal drilling(s) must match the existing oil passages, there is limited room for one of the fittings to extend into the adaptor block.    I have not decided how to handle this yet.
On the crank/flywheel bolts and dowels, the pattern is from the original BMC so we could reuse the flywheel.   It looks like "overkill" but BMC's with the 3.200" stroke are vicious "shakers".     I've seen 1275 race BMC's without hardened dowels and upgraded bolts "shed" the flywheel at high rpm.    Always bad news.    The 999cc "Grenade" with its' shorter stroke was "less" of a shaker.    And the Rover, with an even shorter stroke, will be even less so.    But all Inline 4's have an inherent secondary imbalance, so best to be prepared, since there will NOT be any harmonic damper on the front of this crank.   No room for fitment . . . . .
The crankshaft from Rody is really a nice piece of work, a work of art really.    He did a fantastic job, especially considering all the changes that were specified.    For anybody needing a billet 4 cylinder crankshaft, he should be considered.
F/b
What a fine valedictory, Chris -- and you aren't even retiring.  Thank you very much for helping us remember why we do this stuff -- the rewards are SO COOL.
fordboy628
#7023
Monday Update . . . . .
Starter Photos . . . . .
midget,
Mike Hart called and stopped by the skunkworks late yesterday morning.    He brought the lexan adaptor plate with the final starter placement modifications.
Here are the photos:
In place on modified plate.
Still clocks in tight.
There will be just barely enough room to "sneak in" the inboard attachment bolt using a ball end driver into an allen bolt.    Safety wired after installation.
The starter nose will need to be reduced in diameter to allow adequate material to be retained in the plate to provide threads for the 2 starter mounting bolts.    Mike is going to do this additional bit of machine work.
We suggest that the mock up plate be used for the offer up into the chassis again.    Then Mike can add dyno mounting "wings" onto the new aluminum adaptor plate.    Those wings can be eliminated for final installation into the car.
Your thoughts?
Photoboy
If you can finish off the pan and the oil fittings, I'll come down and get it.  I have to work Saturday morning, but I can stop down Saturday afternoon and grab it, check it to the new driveshaft tunnel, confirm the engine set-back and have it back to you in a fortnight.
This will also let us get an idea as to how to proceed with the header.  I'll do a mock-up with the armored BX, but we need to confirm what size collector we'll need - I'll need that for the mock-up.
I question if the wings will fit in the chassis of the Midget. If you can superimpose the wings for the dyno adapter over the drawing of the Rover/MG adapter, I can do some measurements once the engine is in place.
I want to get the engine running in the chassis - at least able to start and idle - before we spend a lot of time in what is clearly becoming a very busy dyno room.  I don't want to waste anybody's time in the dyno room trying to get this thing to simply fire when we could be churning water, editing the MAP, and taking measurements.
This time -no inverted electrical pins and no leaks!
Yeah - that was me . . .
fordboy628
Quote from: Milwaukee Midget on April 10, 2018, 06:46:55 AM
midget,
I'll try to get those finished this week, but I have a limited availability schedule due to other commitments.
I'll need to check with Mike on the schedule for the adaptor plate delivery.    Not sure what his schedule is.    PLUS, I'm thinking you will want the starter attached this time around.
I don't think they will fit either.    I'll have Mike make some full size "paper doll wings" out of cardboard for the fitup.    If they don't fit, we will have to use other options, such as "wing plates" for the dyno mounts, OR, perhaps using the BMC dyno adaptor plate to bolt up to the 902's scattershield.
Thoughts?
F/b
Quote from: fordboy628 on April 10, 2018, 07:17:15 AM
OR, perhaps using the BMC dyno adaptor plate to bolt up to the 902's scattershield.[/b][/color]
Thoughts?
F/b
I like the idea of not reinventing the wheel.  The dyno has a starter built in, so I can't imagine why we shouldn't be able to adapt an adapter that's intended for a BMC bolt pattern to a plate that was designed to adapt a BMC bolt pattern to a Chevy bellhousing.  Key will be where the splines mount up - we're adding another 1/2 inch there.
Get done what you can get done - I've got plenty to finish in the garage.
(tick-tock-tick-tock-tick-tock . . . )
WOODY@DDLLC
Quote from: Seldom Seen Slim on April 10, 2018, 03:39:39 AM
I might even Xerox that!  :-D :evil: :cheers:
fordboy628
Quote from: Milwaukee Midget on April 10, 2018, 08:33:54 AM
Thoughts?
F/b
Uhhhmm . . . . NO.   We will not be "adding".    We will be "making up" to BMC standard crank/block relationship.
After careful, additional consideration, the BMC dyno plate WILL BE REQUIRED.    Crank hub height on the K was designed to match the BMC crank hub to interface with the BMC trans.
Ergo, setup will be correct with original BMC dyno adaptor mated between the new adaptor plate and the T&T SuperFlow 902 scattershield . . . . . .
See, simple cognitive power wins out . . . .  :wink:
Think about it if some more if you are not sure.
Thinkyboy
Got it - the distance from the face of the new K hub to the back of the new A-K adapter plate is the same as the distance from the original A hub to the original transmission plate.
Ergo, the dyno adapter worked on the A, and will work on the K.
So why were we talking about wings?  I prefer tacos.  :wink:
fordboy628
Quote from: Milwaukee Midget on April 10, 2018, 10:46:03 AM
Mmmmm . . . . especially dollar tacos . . . . .   :-D
:-D  :wink:  :-D
NowI'mhungryboy
fordboy628
Mike reports starter modified and mockup plate modified, plus drilled and tapped for the starter mounting.    He's going to drop it off at T&T tomorrow for a fit check to the block . . . . .
Photos then.
TTFN
4-barrel Mike
Aren't those pretty!   :cheers:
