0 Members and 13 Guests are viewing this topic.
1/2 thick.
Not sure of the diameters of the holes on the centerlines, or for that matter, even if they need to be drilled - they appear to be alternate axial references for the drawing - the center four, all 3".
The starter bolts are known to flatlanders alone . . .  :wink:
fordboy628
#7156
Weekend Update, dos . . . . . .
As promised:  Crankenshaften Spinnin' mit flywheel und pressure plate.   Freitag happenin's below ze "curtain"
The day's progress:
A/    Balance check of the billet crankshaft . . . zehr gut, both ends . . .
2/    Balance check after adding the flywheel . . . .   front: zehr gut    rear: not zo gut
Added pressure plate to assembly . . .  needed to add weight to pressure plate with a small weld bead.
d/    Marking of the flywheel and pressure plate for assembly reference.
Oh yeah, there were bolts installed for the balance.
So, wheels are turning in the background, while you wire the zoo for sound . . . . .
TTF a few days, vacation beckons . . . . .
:cheers:  :cheers:  :cheers:
Ontothenextthingboy
fordboy628
Quote from: Milwaukee Midget on May 19, 2018, 12:39:40 PM
1/2 thick.
2 x 1/4-20 SHCS, safety wired.    In conjunction with a yet to be fabricated rear support bracket, also safety wired.
Flatlanderboy
#7158
I was not expecting the balance action to come about this quickly - THANKS, MARK!
The old pressure plate has a small washer welded on to it to bring it into balance, as well.  Meah - steel stamping - if all it took was a weld bead, that's actually pretty good, in my opinion.
Yesterday was shot with work, but today, I put the finishing touches on the brake box - it's finished and fireblocked.  Plumbed up the brake line, installed the front air springs and repinned the front suspension bolts.
I've got a stainless steel order to place with Burns tomorrow, and we should have a header to work with in a couple of weeks.
I think I've also figured out a double sheer solution for the motor struts - with any luck, utilizing the original A-Series motor mount brackets.
fordboy628
Quote from: Milwaukee Midget on May 20, 2018, 08:48:39 PM
The old pressure place has a small washer welded on to it to bring it into balance, as well.  Meah - steel stamping - if all it took was a weld bead, that's actually pretty good, in my opinion.
Thanks!    But it is time to get crackin' . . . .
Finishing the cylinder head will be my focus when I return.    I expect to be finished early to mid June.
Outforabitboy
fordboy628
Burns is the original, and probably the "Cadillac" of stainless, but if you have the time and want to check prices on SS tubing, bends, collectors, etc:
Specialty Products Design, Inc:
http://www.spdexhaust.com/index.html
Stainless Headers Mfg:
http://www.stainlessheaders.com/mandrelbends
I forget who Viking boy uses, (NOT Burns), those pipes are very nice . . . . .  give him a call if you wish.
Outthedoorboy
Crackerman
I just bought some parts from www.aceraceparts.com.
Ace Race was easy to deal with, and reasonably priced
Mrs. Fordboy sent me a picture of Mark drinking beer after doing some thrift shopping in Iowa . . .
IMG_20180521_162756573 by Chris Conrad, on Flickr
Despite the inclusion of the word "gambrious", I still question the authenticity of the photo - Mark usually wears camo and glasses . . .
Anyway, a quick little pic of potential clearance issues with respect to the clutch slave.  We were running a 4AN fitting - might be a little tight, and thinking a 3 might be sufficient.  This new slave has a canted bung which points toward the frame rail, and might interfere. . . .
IMG_20180528_220023946 by Chris Conrad, on Flickr
forker
in case of a clash, how about a flexible line and a remote bleed point..?
jacksoni
100% agree with flexible line and remote bleed. All the hydraulic throw out bearings have them. Lifesaver. And a small "persuader" will help clearance on the frame rail in any case..... :wink:
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
G/GCC- 194.580 2025
#7165
Quote from: forker on May 28, 2018, 11:53:55 PM
Quote from: jacksoni on May 29, 2018, 04:10:51 AM
ANYBODY who has tried to bleed the slave on a Spridget has cussed up a blue streak.  The stock drivetrain was based on the Morris Minor, and while I'm sure there was plenty of room to access the bleeder under one of these, it sure disappeared when they tried to integrate the drivetrain into a unibody design.  Mark set me up with a very cool remote bleeder and AN line last time, and it works marvelously.  We'll be able to reintegrate that.
This time around, we ARE using a flexible line from the master, and that's due primarily to the relocation of the drivetrain back in the chassis.  The standard combination of hard line and flexible hose won't work with the new engine location, and it also makes engine removal much easier.
I'm looking forward to the day when I can put this engine in and LEAVE IT IN PLACE.  The engine hoist is taking up too much space in my garage . . .
Quote from: Seldom Seen Slim on May 29, 2018, 07:08:31 AM
Chris - the answer to your problems!!
https://en.wikipedia.org/wiki/Skyhook_%28structure%29 :roll:
Perfect.
The next time some buttmunch comes up to me and says, "Do you know what your problem is?", I can confidently look that person in the eye and say without hesitation,
"Yes I do!  I lack a skyhook!"
:-D
jdincau
You might consider a dry break fitting in the line from the master cyl. to the slave. It has worked well for me, the engine has been out 3 times and I have not yet needed to bleed the clutch.
Quote from: jdincau on May 29, 2018, 09:11:37 AM
That could work if I mount the bleed manifold onto the adapter plate - otherwise, I'd need two.
"Yea, though I walk through the valley of the shadow of Lucas, I shall fear no evil: for Amphenol is with me; thy loom and soldering iron dost comfort me."
Amphenol by Chris Conrad, on Flickr
