Quote from: fordboy628 on November 06, 2018, 04:45:06 AM
Midget looks a bit haggard, no doubt mostly due to "job pressures" . . . . . . 'cause we all know racing is nothing but FUN! ? ! ? ? ? ? ?   right?
The problem with managing "Human Resources" is that one tends to have to deal extensively with the first half of the title, while actually being the second half of the title.
I'm the one who raised his hand . . .
Not really complaining - I can't think of 50 other people I'd rather be working with.  But it's insurance renewal time, we've got a VP of Sales retiring, a CEO with an engineering and operations background stepping down, a new CEO stepping up from the marketing side, some client and customer demands regarding state mandated certifications of the staff.
Back to the K.
I'm getting it to pop on start-up, wanting to run, but the minute I hit the accelerator, it dies.  Plugs are carboned up, so I'm running rich.  Right now, the fuel rail is showing 43 lbs, and I'm debating whether to roll back the pressure or shorten up the injector pulse.  They're 36 lb injectors, which seem huge for a 1 liter, but for a 1 liter intended to run full open for 3 minutes, I'm told the shorter duty cycle will give me better injector control above 7K.
I'll start with the fuel pressure reduction before I delve into the madness of the programming - let's just see if I can get it to idle.
WOODY@DDLLC
Chris, it looks like you're the second LSR nut to do 500!  :-o :-D :cheers:
fordboy628
Quote from: WOODY@DDLLC on November 06, 2018, 07:24:40 AM
Chris,
WOW! !   500 pages . . . .   "We come far, you and I."
Who knew? ? ?     Whoever it was . . . .  they should be punished . . . . . severely . . . . .
God save the Oktoberfest.
:dhorse:
Deadhorseboy
Chris, don't go too low on fuel pressure.... high 30s... 38, 39 would be a minimum.  Better to adjust injector PW... the more you do it, the easier it gets.
Quote from: Stainless1 on November 06, 2018, 08:24:41 AM
Bob, I was thinking of doing the math to get the pressure down to where they would deliver about a 20lb/hour at 80% duty cycle.  That's what virtually every calculator I've used tells me I should be at.
You're advising against that method.
Are you thinking fuel spray pattern and atomization issues at the lower pressure?  :|
I'm not a FI guru but I can tell you I used 32 lb injectors at 41 PSI on the NA 1000... Yes it revved higher than yours..... I was well above 80% if I remember correctly.
But I have to wonder how spray and pattern is affected by the lower pressures.  What pressures are suggested by the manufacturer... stick with those.
forker
Quote from: Milwaukee Midget on November 06, 2018, 09:34:57 AM
I'd think you do need more than 20lb/hr; pro-rated from current engine data from the, shall we say, related design group 130hp wants about 23lb/hr, 140hp wants about 25lb/hr and 150hp wants about 27lb/hr. Of British 98RON pump gasoline, that is.
fordboy628
midget,
Now that the "Holiday Lassitude" is in full swing, a gentle reminder that the DOHC K16 crankshaft/engine needs to be turned 180 degrees every couple of weeks.
This prevents valve spring pairs from being at full lift, and full tension, for extended periods of time.   NOT a good idea.
And since the old OHV method of removing the rocker shaft to unload the valve springs is now "unavailable", it's back to "monotonous servitude" . . . .
BTW, turning the crankshaft to vary the valve spring load is is a good idea for all race engines that remain assembled.    The formula for rotation degrees for 4 strokes is:    720/# of cylinders = rotation amount every 2 weeks.
This public service message provided by your friendly, local valve spring supplier . . . . . .
:cheers:  :dhorse:  :cheers:
Preventyboy
fordboy628
And . . . . SSS,
Since I know you peruse the
midget's thread from time to time, I'd like to make a request:
Perchance, might it be possible to, say, temporarily, make available a Holiday Themed icon/Smiley? ? ?
I vote for "Beat a dead Reindeer".
   (beat a dead elf was too close to ummm, aahhh, a ummm . . . . midget . . . . .)
:cheers:  :cheers:  :cheers:
IntheHolidaySpiritbutstillsensitiveboy       (yeah, that's it)
I'm on it, oh long-suffering, but now elated fan of the Chicago Bears.  Best defense in the division.
In fact, I'm a bit ahead of the curve, in that I did get the water drained out and replaced with anti-freeze before playhouse temps nosedived.
As to beating a dead reindeer - all one needs to do is drive at twilight on any given Wisconsin trunk highway with your Go-Pro on, and with a little time, you'll have sufficient footage to make your own GIF.
Happy Thanksgiving, to all who missed my note yesterday.
jdincau
Permanent note on my calendar; turn the crank 180 every week and charge the battery every month.
Koncretekid
#7496
"BTW, turning the crankshaft to vary the valve spring load is is a good idea for all race engines that remain assembled.    The formula for rotation degrees for 4 strokes is:    720/# of cylinders = rotation amount every 2 weeks."
So for a single cylinder, 720 degrees/1 every 2 weeks.  Won't that put it on exactly the same valve spring position?  Of course, for a single cylinder motor, we can just put it at TDC on compression stroke and the valves will all be closed anyway!
fordboy628
Quote from: Milwaukee Midget on November 23, 2018, 09:06:33 AM
I'm on it, oh long-suffering, but now elated fan of the Chicago Bears.  Best defense in the division.   Might be a bit better than that after Turkey day . . .
In fact, I'm a bit ahead of the curve, in that I did get the water drained out and replaced with anti-freeze before playhouse temps nosedived.    x-lent
IF, you live long enough, every worm can turn . . . . . . .   :dhorse:
fordboy628
Quote from: Koncretekid on November 23, 2018, 01:46:29 PM
Hi Tom,
Of course you are right, the "formula" (rule of thumb? ?) doesn't work out for 1 or 2 cylinder motorcycle engines.   It's intended for multi-cylinder applications starting at 4 cyl inline.
But, clever bike guy that you are, you already have a solution.
F/b
fordboy628
midget,
Snowmageddon @ the "ranch".   12+ inches forecast for north eastern portion of the Illini nation . . . .  3" to 4" already on the ground here, and the "big blow" has not arrived yet . . . . . BUT, my TORO started on the second pull.
Hope you are prepared . . . .   Looks like the forecast for Beerhaven is a bit kinder . . .   ONLY 6+ inches.
Welcome back to Hoth, Earthlings . . . . . .
Retiringsomewherewarmerboy
