0 Members and 38 Guests are viewing this topic.
gearheadeh
Quote from: Milwaukee Midget on June 19, 2011, 01:05:07 PM
I do intend to take this thing down to Great Lakes Dragaway for a tune and test night.  Better to embarrass yourself 40 miles from home than 1500.   :wink:
Chris, now you are talking! What does a more or less stock MG Midget do for a 1/4 time? What time are you hoping to achieve with your modified but smaller power plant?
"Better to embarrass yourself 40 miles from home than 1500.   "
I dunno.... 40 miles away, too many people would know who I was.  :-D
Regards, Neil   Tucson, AZ
Quote from: gearheadeh on June 19, 2011, 05:15:35 PM
I've got a collection of road tests dating back to 1961 - typically 18 second 1/4's were the norm for 1098's with 4.22's or 1275's with 3.90's.  Shifting at 5,500 was typical.
I'm more interested in my trap speeds - I don't intend to launch it hard, and all I've got for rear tires are a set of sacrificial 155 - 80R 13's that are harder than a bowling ball.
If I can get it to 7500 in third gear by the traps, that'll put me at 85 mph - I'll know at that point if I'm chasing my tail.
Quote from: manta22 on June 19, 2011, 06:15:34 PM
Let me rephrase that - cheaper?  :-D
I reckon the crowd will be so astonished that you can actually fit in it that they'll be standing there with their jaws on the ground anyway :cheers: :cheers:
We've all made fun of it - chief among us myself - but once in place, it verges on comfortable.
Entry and exit IS tough, but once I'm actually IN and buckled, it's good.  The racing seat is set back by the rear bulkhead, which added better than 4 inches of leg room over stock.  The seat bolts to the crossbar on the floor, and at it's lowest point it's about an inch from the floorboard - stock is about 4 inches.  I've maximized every inch I could, and for a driving position, it works well.  The controls fall right to hand, visibility is good, and while I wouldn't want to drive it in a 50 mile road race, I'm sure I could.
About 8 years ago, I was at the June Sprints at Road America, and chatting with a guy out of Colorado racing a Huffaker prepared Spridget. He was about my height, and I asked him how he was able to fit in it.  He invited me to jump in and check it out.  Now granted, SCCA lets you go with no top, no windshield, and the cage is not nearly as complex as what the SCTA requires, but it clearly was doable.
This should spin pretty tight.
75 lbs of shavings later -
Off to heat treatment on Monday.
THANKS, GREG!
4-barrel Mike
Quote from: Milwaukee Midget on June 30, 2011, 08:20:06 AM
How much did that thing weigh stock  :?
Mike, Greg said he was going to put the billet on a diet.  Maybe he was being facetious - I never weighed the billet.  But given that the crank has the throw of a Cox 0.49, it wouldn't surprise me.  :wink:
Koncretekid
MM,
A couple of weeks ago, you mentioned the following (sorry, I'm always a couple weeks behind, it seems):
    "And after a talk with Sparky a few months back, he recommended placing some small oil nozzles directed to the back of the piston for longevity. After seeing Grummy's teardown of the J/S tank, and the heat on the small ends of the Holden V6, I'm thinking that's not a bad idea."
Enlighten me for being dense, but which is the back of the piston?  I wanted to add something like this on my BSA single (front being the exhaust side), but didn't have time to come up with any solutions.  I thought about drilling the big end of the connecting rod with a small hole, maybe .040", that would direct a small squirt of oil up onto the inside of the piston on the exhaust side, but didn't know if this would compromise the strength of the rod, or even work at all. BSA did it on their 650 twins to squirt oil, apparently onto the main crank bearing (ball or roller in a dry sump motor.)  I have no idea if it actually worked.  Any ideas?
Quote from: Koncretekid on July 02, 2011, 04:12:07 AM
Tom, you're not dense - I'm just sloppy with language. :-D
I'm glad you brought it up, because I'm rethinking my position.
The underside of the piston is what I should have said.  I was planning on tapping into the oil gallery and plumbing a line in the crankcase with 4 small jets to bathe the underside of each piston.  This is more to take heat away than to lubricate.  The plan for the jet is simply a tip from a wire welder  It's a suggestion Sparky made to me, and it all has merit.
My concern has become whether my oiling system has sufficient capacity to deal with four additional "controlled leaks" of this nature.  If I were running a dry sump, I don't think it would be an issue, but my oiling system is essentially stock.
So as we speak, the jury's out.
grumm441
Get the pistons coated instead
Quote from: grumm441 on July 02, 2011, 11:11:21 PM
I like your thinking - rather than trying to draw the heat away, keep it out in the first place.
If it were supercharged, I'd do both.
Koncretekid
MM,
I agree with you on the additional 4 leaks in the oiling system.  I don't think the British overbuilt very many parts, and the oil pump may be at it's limit.  One of our BSA B50 forum members actually measured oil pressure and found that at high RPM's, it became negative.  His reasoning was that the centrifugal pump effect of the rotating crank was actually sucking more oil than the pump could provide.  So just when you need it most, the squirters could fail.  Scarey. I like the idea of ceramic coating of the piston, but with only 10 days til Loring,  I won't have enough time. At least at Loring, I won't have to hold it WOT very long (I'll probably ride the 1st mile quite leasurely, then open it up).
grumm441
Quote from: Koncretekid on July 03, 2011, 05:26:57 AM
MM,
I got the crowns ceramic coated and the skirts moly coated after seeing the disaster that was the last engine that I didn't build
The negative oil pressure could also be a combination of the centrifugal crank filtering setup and a cavitation problem at the oil pickup. this is usually where Dr Goggs pipes in about not getting me started on cavitation and oil or fuel pumps.
But it made me laugh thinking of negative oil pressure. Only the English could make an oiling system that worked in reverse
Quote from: grumm441 on July 03, 2011, 05:50:59 AM
MM,
Tom, Grummy, thanks for the info.
It's occurred to me that since I've actually shortened my crank throws by three quarters of an inch, and that the Midget has a fairly deep pan, if I build a windage tray, I could likely throw an extra pint or two of oil into it with little negative impact.  I've also got an adjustable oil pressure regulator/valve.
It's a balancing act with the A-block - too much pressure and it blows out the seal - too little, and - well, let's not jinx ourselves.
Tom - best of luck at Loring.
Grummy - I can just hear that call from the engine room - "Main Bearings!  This is the sump calling!  Send me more oil!"
Hail Britannia. :wink:
