V4 Dodge
Started by RichFox, August 03, 2009, 09:07:11 AM
38flattie
Wayno, We were pretty swamped, and a whole lot overwhelmed, when I saw you at Speedweek. I'm really hoping to be able to have a good chat with you, if you have time, at El Mirage!
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
Elmo Rodge
I have starting line duty Saturday morning. We'll find a way. Wayno
38flattie
I have duties on Sunday, but like you say, we'll make it happen!
RichFox
For your eyes only. Looks like the hood is going to need some work. I am going to make the sample push rod and send it to Smith Bros next.
zenndog
Good thing I am heading over there this Sunday or you will have the whole car together and I will miss all the fun! Looks good. Z
RichFox
It's just sitting on there so I could measure for the pushrods and stuff.
zenndog
#231
First off, I was at Rich's today, which was my original plan and what I had e-mailed him. Since I had posted the post above about coming over on Sunday, Rich was not expecting me when I showed up this morning. Ops. No problem.
Here is a shot of the header flange with stubs brazed in for the headers. Just a detail pic.
Here is a shot of the rocket arm assembly
Rich has the test springs in place on the #1 intake and exhaust to check valve clearance when the pushrods come in
Everything is just set in place so I flipped over the rocker arm assembly to show a little glimpse into how it is put together. Rich fabricated the rocker arm stands and the plate.
Close up of the throttle bodies and intake "manifold", modified Ford throttle bodies and intak fabricated by Rich, of course.
Close up of the lifter cover, fabricated by Rich.
Rich wanted to make a second test pushrod to double check the length, here is the rod set to length
The head studs were test fit and were tight. We thought it might be the copper head gasket ( fabricated by Rich ). So Rich is drilling out the stud holes.
I took a minute to take a couple of pics of Rich's next engine project in the wings. Lincoln 368 Y-block. Rich has been collecting parts for years. Billet cam blank, forged flywheel, lakewood bellhousing, just to name a few of the goodies waiting to be installed on this engine.
Checking the head studs on the gaskets
We checked the rocker arm assemblies on the studs, they were tight also so the assembly was taken apart and Rich opened up the holes.
Done
The studs under the rocker arms were touching so Rich shortened them on the lathe. He also had to shorten two of the othe studs that screwed into blind holes.
Here are before and after shots of the studs under the rockers
The most of the head studs were still tight so Rich is going to order a reamer to open the holes for the head bolts. There are also two head studs that need to go in two "pockets " under each of the exhaust ports at the end of the head so Rich is waiting for some set screws he ordered to arrive to do the job.
Here is the engine at the end of the day
Night
maguromic
What a fantastic build! Tony
This is hard on an ol' guy. I just go through all this beautiful Dodge porn and then Tony changes his avatar!
To Rich, awesome project, looks great!  :cheers: :cheers: :cheers:
To Tony, awesome avatar, looks great!  :cheers: :cheers: :cheers:
V4F STR 60
Great to see you guys have so much progress since we were there last month.  Awesome job!  Keep up the good work.  See you on the salt!
Montana Dodge Boys Fast Four Special
1928 Dodge Brothers Vintage Flathead Four Cylinder Roadster & Lakester
Landspeed Records
Bonneville
2009 V4F/STR 115.681
2009 V4F/GR 116.439
2009 V4F/FR 117.597
2010 V4F/BSTR 127.352
2012 V4F/BFMR 130.843
2013 V4F/BGMR 142.956
2013 V4F/BFMR 143.254
2013 V4F/BGR 138.395
2013 V4F/BFR 138.984
El Mirage
2016 V4F/BGMR 140.961
www.facebook.com/MontanaDodgeBoys
www.fastfourspecial.com
Rich when you get through with that Y block project I may still have a 56 F250 it would look great in----that is on down the road for both of us I am sure!!!
RichFox
Zenon is kind of forgetting about the '28 Chevy with the Olds head that I want to get running and the V6 for the Bantam that needs building. Then there is his Stude head project and maybe a Ford 400M he has in mind.
zenndog
I not forgetting about all that stuff
I think I was referring to Bonneville engines.
I think it would be a good way to christen the Stude Pickup.
Obviously it is down the road.
38flattie
Guys, that's some fantastic work, on a very cool engine!
I can't wait ti see this one-keep up the great work!
zenndog
During the week Rich reamed out the holes for the head studs to 17/32". We started out the day setting the head on the engine but were still having issues with the head studs binding when we tried to screw them in. During this somewhat frustrating process we noticed that the head was not sitting flat. We determined that the #4 piston was lifting the head slightly. We removed the head again and discovered this "bump" Rich had had welded in to aid with sealing near the head bolt hole was in the path of the piston slightly. Rich decided to grind it down with the die grinder.
After Rich ground down the bump so there was sufficient clearance, we  set  the head back on the engine.  The piston cleared but the binding of the studs became worse! Rich is going to order a couple more reamers to ream the holes to 9/16" and that better work. Maybe he will think of something else to do during the week as he takes time to ponder the problem.
In the mean time, even though we were a little down about the head we did some work on the water lines to get the water hooked up and ready to go.
And here is a shot with the valve cover on just for motivation
Have a great week!
