V4 Dodge
Started by RichFox, August 03, 2009, 09:07:11 AM
zenndog
Yes, somehow this is all my fault.
RichFox
Zenon is taking a little time away from the thing this week. So while he wasn't looking I made a new trick header flange. It's a new theory of mine concerning controlled back pressure. It should also hold the head in line when it's bolted to the spare block Roy Creel gave me. Hopefully soon after the July tune up meet it will get to a welder.
zenndog
Here are some pics. The head is off to the welder.
These two pictures show some trick spacers Rich made. The block Rich built for the M&B head has 1/2 head studs which Rich installed. The original head studs for the dodge block are 7/16. Since we are using Rich's extra block as a "jig" while the head is tacked and welded on one side, We had to have the head locate properly on the 7/16 studs. Here are the pics.
We bolted the three parts of the head to the extra block
Rich is bolting on his exhaust flange alignment "jig"
And off to the welder
zenndog
#438
Almost forgot, a close up of the spacer where the two halves of the head meet
The head may be welded by Friday.
tauruck
Awesome mod. :cheers: :cheers:
Thanks for the photos.
RichFox
This is what it looks like these days. Needs a little more welding and a bunch more welding.
Wow, I wonder how many amps it took to weld it.
RichFox
It's not really that thick. Your just welding the water jacket mostly.
4-barrel Mike
From reply #423:
lsrjunkie
I can only imagine how that goes... weld, weld, weld, pressure test, weld, weld, weld...
Looking good guys! That little motor should breathe quite a bit better after all of this. Nice work as well.
RichFox
#445
With proper prep and preheat, one weld one pressure test. No leaks. Now another try at attaching pictures. All right. I shrunk the pictures. I changed the name. This says there is already a file with this name. I don't think so.
jpm49c
lsrjunkie
Good to hear there's no leaks.  :cheers:  I've no concept of welding aluminum, but it looks like the head is turning out great.
RichFox
Still trying. I got the pictures in. It was harder than cutting the head.
jdincau
