V4 Dodge
Started by RichFox, August 03, 2009, 09:07:11 AM
Tman
zenndog
#406
Okay, we weren't able to work on the head for a couple weeks. Today when I showed up at Rich's house I found out he had drilled the holes already.
Rich had one of the heads from his bantam truck on his mill so that had to be finished first. Once we put in some helicoils we could mount the center of the head and start machining.
As you can sort of see, we scribed the profile of the head onto the center piece which needs to be machined. We milled the slight angle which is on the intake side and the angle where the valve cover rails will be.
Well I hope that all makes sense. I had to leave, Rich was threatening to finish it by the time I come back.
tauruck
That's great engineering and it does make sense.
I love it. :cheers:
Speed Limit 1000
That is going to be amazing :cheers:
gas pumper
Yes, amazing! And thank you for keeping us informed and educated.  :cheers:
Frank.
Crew for 608 AA/GL.
Crew for The Flying Seven, 7207, XO/GCT, V4/FCT Loring.
Crew Chief: 7207 XO/PP.
Tman
Pretty slick! What are you guys doing for a Valve cover?
They are going to make it look like a FlAT head with Hemi plug tubes sticking  straight up of course!!  :wink:
RichFox
My plan is just to take two 318 valve covers and make one long one. All the excess aluminum spacer will be gone shortly.
As has been the case with all your work, very impressive.
I have always enjoyed all of your work that was published in BRN  :cheers:,
mtkawboy
beautiful workmanship guys
RichFox
I am trying to post pictures of the head with the spacer roughed to size. But this thing says there is already a post with the same file name. No kidding. Now what do I need to do?
wheelrdealer
Quote from: RichFox on June 14, 2014, 01:24:02 PM
Change the name to your photo file. Most camera software logs the picture file under a series of numbers...all in a similar fashion and that file name has been uploaded somewhere. On a PC and MAC its easy to change file names.
RichFox
I did, twice. After resizing the pictures. If you are interested enough look at http://www.jalopyjournal.com/forum/threads/june-banger-tune-up-and-drive-em.927035/#post-10468003. Ryan makes it easy to post pictures.
Tman
Lets see if I can help?
Tman
Looks great guys!
