240 inch V4 Harley picture
Started by mtkawboy, August 20, 2009, 09:12:28 AM
mtkawboy
Did anyone happen to get a picture of the Harley or look a like that had the TP 240 inch V4 engine in it ?
John Noonan
#1
That bike is 214 Ci
It was built by Bob Moreland I believe.. :cheers:
mtkawboy
Maybe I misunderstood him, I thought he said 240.
Cajun Kid
Stan,,, who knows,,, maybe
TP  =  Tuned Port , Turbo Powered,
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
theazoldcrow
Guessing don't count -- let's hear from somebody that knows.
willieworld
#7
i will give it a try---the bike is a V4 engine --ive talked to the owner at auburn harley davidson--at el mirage ---and at speed week 09----he takes a set of cases spreads them apart and machines a center case so that he can bolt on 4 heads and barrels --which only makes the engine  about 8 inches wider ( im guessing here)  the rockers are extended from the right heads to the left set of heads  so no need for another cam chest ---first time i saw the bike i noticed it had 4 exhaust pipes and that the engine fit under the fxr gas tank---the crankshaft is made by press fit and welding ---all in all a pretty good idea--the engine is a little spendy for my budget---i saw the bike in impound and i think they were getting ready to pull the front heads --not a job i would want ---i have a card somewhere if anyone is intrested let me know-------------willie bucha    not a new idea     http://thekneeslider.com/archives/2007/01/15/twindian-twin-engine-indian-motorcycle/
willie-dpombatmir-buchta
John Noonan
TP Engineering..= Tom Perone
The kit allows you to take two Evo based engines and mount/install them together via the new center section.
On the dyno the bike makes good HP (can't post it because I don't know if Bob or the owner want it mentioned) however it should be enough to run 170 mph.
If you look at the bike hard enough you will see a little bit of Hayabusa in it.. :wink:
J
isiahstites
Quote from: John Noonan on August 20, 2009, 08:37:33 PM
J
Just a little........
754
It better do at least 170...
a local fellow from here runs over 160, with a 1 cylinder Harley 1000cc.. :-o
John Noonan
Quote from: 754 on August 20, 2009, 10:17:16 PM
Oh yeah:::
It better run over 160.
A local fellow from here runs over 152 with a 1 cylinder Harley 500cc :-o  and that's with real American miles per hour none of those silly Canadian Kilometers. :-D
J
754
I meant BMPH
= Bonneville Miles per Hour..
1212FBGS
and Tatro did that 152 at el-mo  :-D.... yes 1 clyinder 500cc...+ big load of nitro and nitrous
kent
bak189
4 Cly. Harley (side by side) nothing new.....Kenny Lyons build and raced one at Bonneville back in the early 1980's.....if I recall it ran around 180mph.....we all stayed together at the "famous" Patio Motel and worked on our racing bikes in the rooms.  Those were the days!!!!!!!!!..............................................
Question authority.....always
