XXO/BVGC '38 Chevy Coupe Build
Started by 38flattie, July 21, 2010, 06:34:16 AM
GH
Buddy, go with the Jerico, you will not have any trouble.
38flattie
Sorry about posting again, but I just figured out I posted on the old forum!
Thanks Gary! I'll see what the finances look like!
Pinkees is done with the panels!
Here is a drawing of the axle fairing we're contemplating.
Have a Happy New Year!  :cheers:
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
And it looks just as good on the new forum! :-D :-D :-D
38flattie
Thanks Pete!
Stan, money may dictate that I wait until next year for them. I'd like to have them, but I'll have to wait and see....
A new hydraulic clutch system, stronger tranny, and engine management system for El Mirage take precedence.
I want to try and control detonation, so I'm switching classes for El Mirage, to try and get a feel for the engine. I'll run a MSD box., and retard timing with boost, in the XXO/BGALT class.
I'll try and get a pass in with the XXO/BCCC configuration, if the car runs strong.
LittleLiner
38flattie
Thanks Art!
Littleliner was kind enough to point out that I would need front fenders to run XXO/BGALT at El Mirage. Bobby Sykes concurred!
So, the fenders are going on for that class, and we'll still run XXO/BCCC, without fenders, if the car is running good. That should give us a good baseline, and be a ton of fun! :-D
38flattie
#802
I've been concerned about the Muncie holding up behind the FlatCad. I found a Liberty Ford toploader crashbox, with a Hurst Ramrod inline shifter, complete with slave and throwout bearing. I think it should work a lot better!
Gearing is 2.78, 1.93, 1.36, 1.0 .
Now I just need to find a Ford FE SFI bellhousing!
38flattie
Ok, I think I have all the changes for the year planned out, with the exception of the exhaust.
Where in the world should I run the exhaust out of this car??!! :?
#804
Like a conventional Turbo sustem in Reverse, slightly Up, forward diagionaly, down and back.
Buddy think Monza then!!!
38flattie
#805
Sparky, I have no idea where that would end up, exactly, but it's good to see that you're in good spirits this year! :cheers:
I'm actually debating running out the lower sides, blowing the exhaust down the lower portion of the car toward the rear, or simply going straight out the rear of the car.
Buddy,
Are the second gear dog rings as bad as they look in your picture?
38flattie
No Rex, they're not. Just a bad pic angle, I guess.
38flattie
Because we're going to run an HEI and engine management, and therefore switching classes for El Mirage, I'm thinking of adding an alternator. I'm afraid the HEI, gauges, fuel pump, and electric chiller water pump will be too much of a drain on the battery.
The engine layout is done, and there is not much room to add anything else. In addition, we will not need the alternator in vintage class, with the magneto, so I don't want to spend a lot of time and effort on this.
I'm leaning towards a mount on the rear end, and running it off of a pulley at the driveshaft. Any one run one like this, or have experience with this setup?
Queeziryder
Hi 38Flattie
I did a system on a friends drag race car using a small motorcycle alternator off a Kawasaki ZX10 which gave approx 15A at 13.8V
It was self generating and regulating, but did need a disconect or would keep the engine running even if you switched off the MSD.
It was approx 6" in diameter and we ran it off a standard pulley at engine speed with no problems.
You might be able to get a small alternator off a Jap import that would easily do the job for you.
HTH
Neil
Old enough to know better, but too interested in speed to care
