XXO/BVGC '38 Chevy Coupe Build
Started by 38flattie, July 21, 2010, 06:34:16 AM
38flattie
Thanks Neil- I'll keep that option open!
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
Simple single wire alternators are rather common on oval track cars. You can use a larger pulley on them so they don't absorb as much power and they're still adequate for keeping the battery charged. With what I've seen of your build so far I don't think designing a mount and drive system will be a challenge.
Buddy,
Wouldn't it be easier just to double or triple the batteries and avoid all of the hassle of an alternator? No way could you drop the voltage on a set of 2 or 3 good batteries wired in parallel. Back to the pits and a good charge and you are ready for the next run.
Just a thought.
38flattie
Yes Rex, it would be easier! Guess I was over thinking the issue-thanks!
Isn't over thinking what most of us as racers specialize in???  :roll: :roll: :roll:
38flattie
most water pumps and alts function best at not over about 5000 rpm shaft speed.
38flattie
I just got back from Pinkees, where Erik had mocked up the axle fairings we were looking at.They are a lot bigger than I thought, and now I'm not sure that they might not cause more harm than good!
Erik thought switching to a tube axle might help, and going with quarter eliptical springs?
Buddy,
The fairings look great from the front but it is the back side that is important, what do they look like?? Remember that even if the fairing adds frontal area if it is don correctly and its Cd is sufficiently smaller it will be better than all of the suspension stuff hanging out in the air.
38flattie
Rex, I think you're right, in the fact this this would work, if it were done right. Unfortunately, I don't know enough about aero to insure that it gets done right. I'm going to step back for a bit, and study up on what I need, then attack it again.
In the mean time, I'm going to concentrate on getting the changes done to the car, that we need to run it- new transmission and driveline, different fuel and water system,mounting the parachute on the car, different pushbar, and different brake and clutch pedals. We struggled with the cable clutch setup last year, and now will have a hydraulic one.
Of course, we still need to get the engine assembled and on the dyno!
55chevr
Looks like the Miller front wheel drive fairings from the 30-s
38flattie
55chevr, I just spent the last hour looking at Millers! :-D
I'm still looking to get better aero, and thought about a narrower tire. Can a tire like the Goodyear D1445, at 2.5" width be used? I can't find anything that tells me if they will handle the weight.
Garry Odbert was kind enough to offer me some aluminum racing spindles, so that I could get rid of those rotors, and clean the front end up some, so tires like this, if they will handle it, would sure be nice!
Speaking of Garry, he's been doing a lot of port work on his Caddy flathead. He's up to 180 CFM on all his intakes, and feels he can get some more!  :cheers:
Garry also picked up a cam blank from Joe Panek, and is also going down the Harley roller lifter road.
desotoman
#822
Quote from: 38flattie on January 16, 2012, 04:22:45 PM
Buddy,
I like you and don't want to see anything happen to you or anyone else who drives your car. With that said I would never ever consider that tire for the front of any car except a Dragster that travels the quarter mile.
38flattie
Thanks Tom!
I kind of thought that, after looking around and not seeing cars running them.
It sure would be nice to find some acceptable, safe, narrow tires, though!
38flattie
Dale got the valves installed, and they might be the biggest valves ever seen in a flathead! Russ Meeks coated everything for us, and they're nice!
And of course, Dale had some 'rocket fuel' on hand!
Valve train is Comp Cam, with Manly valves, 1.94" intake, 1.78" exhaust-140 lbs on the seat (installed height of 1.8") and 290 open.
Pistons are next!
