Australian Belly Tank
PorkPie
Quote from: manta22 on August 24, 2014, 03:08:23 PM
Thanks, that was a pretty good speed for 1939, especially for that engine displacement! I wonder if that speed was on the autobahn or at AVUS?
Neil,
Autobahn streak close to Dessau (East Germany), which was special built to go over 400 mph with Mercedes T80
Thanks, Pork Pie. I'll have to look at a map to see where Dessau is.
Doesn't look a day over 138.
Avoid the cracks in the west coast while you finish up your vacation.
And I will remind you - AGAIN - there ARE states east of Utah.
Biggest regret of a rained out Speedweek was not being able to put you behind the wheel of the Midget - if for no other reason than to have photographic evidence of you driving a Pommy car.
Your friend -
Chris Conrad
PorkPie
Quote from: manta22 on August 24, 2014, 10:35:27 AM
Thanks, Pork Pie. I knew you would know which cars I was thinking of. How fast did the Mercedes go and with what horsepower?
Neil,
here the missing data....179 ci, app. 483 hp
The car they use was originally for the standing start record...but the second car for the flying kilo had trouble with the engine...they was lucky enough that the tank was just big enough to run also the flying mile....so this version set both, standing and flying records.....the second car was a little bit different in the air intake (nose) and the windshield...left and right close....
Thanks, Pork Pie. You are an encyclopedia of information.
grumm441
He must be like 170 or something by now
Happy birthday Goggles
tauruck
4-barrel Mike
Yes, Happy Birthday, where ever you are!
Dr Goggles
I just had blueberry tart in Yoncalla, watched over by the little Puke, Jim L and some guy who's name I can't remember, thanks for the directions Pa you cunning old sod.......
Next time I come to Oregon I'm bringing a lifejacket and some flares..........
James,  to a great birthday---so sad didn't get to see you this season
Happy Birthday whenever and wherever it was James....  :cheers:
I guess I will have to mail you your tshirt since you have decided not to stay for the WoS  :evil:
G, are you coming over this year?
See you next year I hope
Dr Goggles
Quote from: salt27 on January 18, 2014, 04:35:06 PM
280 pages and I can't find if you mentioned the weight of "The Spirit of Sunshine" or not.
If you would have to kill me if you told me, I'm not interested but if it was just a slight maiming I'd like to know.   :-D
hey Don, I felt guilty last night when in the middle of all that hospitality you asked me again how much it weighed. When I get home I'll make a point of making E By Grumm take it down to a weigh station.
Elmo Rodge
Birthday?  :? Another one?  :-P Make it Happy, my friend.  :cheers: Wayno
Dr Goggles
Yeah, Wayno pretty much every year I have one.
Where's Sid, the least he could do is wish me well for remaining one year older than him, whippersnapper
Reverend Hedgash
#4634
Quote from: superleggera on August 24, 2014, 03:15:38 PM
Instead of a full streamliner concept that fits over everything, the images above of adding wheel pants (ala Carbinite) or Orpheus-style housing would be interesting. (and fairly easy to integrate without damage and could be done remotely and shipped easier due to smaller sizes)  The addition of these panels would increase surface area itself -- but the frontal aspect would remain about the same and the airflow would be cleaner than the existing exposed wheels.
Given the baseline testing of the belly tank and known data about everything ala speed/gearing/displacement, it would make an interesting scientific project without breaking the budget.  Possibly three iterations or more of testing:  (and feedback in regard to directional stability)
1) Simple Carbinite NACA 6600 profile derived wheel covers over all four wheels (or rear two only). Or other shapes?
2) Orpheus configuration of integrated front/rear cover.
3/4) Variants of 1/2 with additional appendages to cleanup airflow over suspension / axles / etc.
We had considered this in a super cheap way a few years ago with using some Morris minor fenders as "cheater guards" to simply change the class, and we even built some bolt on ones that didn't do anything for aero but did the class change only to cheekily mop up two open class records. We have yet to run them though.
This is something to consider as an exercise indeed even if it is for interest sake for all concerned and I am sure there would be much interest and discussion derived from it. I could pretty easily draw the NACA shape in 3D and cut it a mold using our 5 axis router at uni...
The thing is though your version 3/4 above is sort of what I am proposing anyway but hopefully in a more stylish manner than the accretion method described would produce (IMO).
The main issue in my mind is the use of ground effects or not. If that was the piece cleaning up airflow as you describe in 3/4 then I could make a couple of different types that gave proof of concept. If it doesn't work then there is no point building a whole new car based on this idea and better to go a different route.
There are a number of factors governing whether it will work or not in the manner we want it to work which will include which record we are going for (ie what top speed), the type and power of the engine, the final cD of the car including the ground effect device compared to not having it, all of which is not yet decided but each are important variables. What I want to do is see if there is a best set of variables given established records and run that package.
Superleggera you have me thinking... if we are to build a new chassis then a modular designed body might be the solution where it is designed with the ability to test all aspects of bodywork... it is a matter of defining joint lines and hard points (a contemporary auto manufacture methodology).
I still want to do some proof of concept stuff on the SOS chassis though...
rH+
