A class bike build advice
Started by MTABike, September 15, 2010, 02:26:01 PM
MTABike
please delete
55chevr
Get the rule book for where  you are planning to race ... My bike is 72" wheelbase and rigid ... a bit rough on the body at Maxton but no problem at Bonneville and Loring ... the reason for sport bike stuff is cheap and available ... tires are no problem to get ... and the stuff works.
55chevr
I used an S1W Buell donor bike ... nice wheels / front end ...
The tubeless tires on mags are somewhat safer than tube types on wire wheels.  Lighter, too.
I always thought it was a good idea to attach the rear wheel.
Quote from: Stan Back on January 26, 2011, 06:53:27 PM
Roadsters ya, bikes sometimes...
It looks like you have raised yourself up into the wind unnecessarily, A bike, think a little more outside the norm.  The low seat position is good, the high gas tank is bad....  :|
You can always add ballast in front of the wheel, the more room you have to hide stuff from the wind behind the engine and you the faster you will go.
Just my thoughts, good visuals... stare at the pictures, play a little and take more.
55chevr
Rake: 35 degrees --- perfect
Wheelbase: 78" --- good ( mine is 75 - works well - very stable at 150 )
Seat height: 24 --- good -
octane
#8
Hi Scott
You say I'll run in the 650cc A-BG class.
What kind of blower/turbo set-up do you have in mind ?
Quote from: MTABike on September 15, 2010, 02:26:01 PM.. With an inline 4 tearing a wide hole in the air is my front tire even really going to make much of a difference?
Here's something to have fun and play around with
concerning frontal area/drag/HP
that I used for my little supercharged Indian:
Go to : DRAG LOSS CALCULATOR
( and scroll down for 'calculator')
For calculating the frontal area I took a pic from the front
with markings for each 10 cm. ( This is what the bike looked like back then.
It's a bit different today )
...then made a 10 x 10 cm grit
( Arms tucked in more, on this pic )
...and calculated the area.
That came to 0.3355 sq. meter ----> 3.605 sq. feet.
As the parts further back from the grit-line appears smaller than they are,
so I adjusted it up to 3.9 sq. feet
I set the cd to 0.9, based on a know figure for another bike
and punched the figures into the drag loss calculator
Don't forget to ad to the total weight of rider: helmet, leathers, boot, gloves
cd----------------------.9
frontal area-------------3.9 sq. ft.
weight------------------539 lbs.
speed-------------------100 mph
Horsepower needed....: 24.9
speed-------------------120 mph
Horsepower needed....: 42.3
Good luck with your bike !
dw230
The late Cliff Gullet had a sports store in Bozeman, Yamaha bikes, snow mobiles, water craft, etc. His brother, I'm sorry  - his name escapes me right now, runs the shop now I believe. They are experienced salt racers. I am sure you could get some good input from them.
Anyone remember the store?
Buickguy3
  Dan
That would be Team-Bozeman.com. They are the Yamaha dealer.
  Doug
                   [America]
bak189
Lars, those leathers certainly fit you a lot better then they did me.....especially now, I just got to loose weight...oh, sure
Question authority.....always
dw230
Cajun Kid
Quote from: dw230 on January 27, 2011, 02:16:48 PM
Man, I wish it was dw320 !
When you grow up lil 230 you can be 320  LOL
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
hotrod
#14
QuoteOctane:
Thank you for the link.  I'll have to put something to scale off of in my next mockup pictures so I can start getting some ideas of speed vs. power.  I'm still a bit up in the air about which turbo I'm going to put on the bike, but right now it's looking like it will have a MHI TD04L-13g (stock turbo from a WRX in the US) for this year.
Scott it might not make any real difference, but the stock TD04L turbo on the Subaru WRX is actually a 13T compressor not the 13G as widely believed. The compressor inducer does not have the right diameter to be the 13G.
See my notes in this Subaru forum turbo listing for details, and my estimate on peak flow for the 13T.
http://forums.nasioc.com/forums/showthread.php?t=699989
http://forums.nasioc.com/forums/archive/index.php/t-278517.html
Larry
