NACA 66 Special A/BGS
Started by robfrey, September 23, 2010, 06:12:28 PM
No, but who was that?.
I think I might know. :-)
7800ebs
I was wrong but thanks.
That was 2001!.
I would have loved to see that. :cheers:
4-barrel Mike
I timed Don's runs and signed the time slip and record certs, I am now a crew member on the Turbinator II.
PorkPie
Vesco, FIA October 2001
No, I've never seen the timing slip.  but -- I'm pleased to say that both Nancy and I saw that run.  Like so many others -- it was something to see and to remember. :cheers: :cheers:
Buickguy3
  Pork Pie, Is it normal for the chute to fly so high?
                   [America]
only if you want to cringe when you see the photos---I have been in a car that the chute kited and lifted the rear and pulled it side ways  was fortunate to  "steer into the slide" and stayed in front of it
PorkPie
Quote from: Buickguy3 on May 13, 2014, 07:44:41 PM
Nope,
but so pictures helps the teams to fix the issue.....the Nish Streamliner had similar problems...and the #55 roadster was one with the twist behind the 5 mile marker....
Frankie7799
Rob, with the engine change, will you guys still be on the salt in August?
Burkland had the same problem long ago.
They resolved it.
Educate me a little, please: what might cause the chute to "fly high"?
7800ebs
Contact Joe at DJ Safety..
He is the guy .. he worked close with Jim Diest
He knows his stuff..
Quote from: Jack Gifford on May 14, 2014, 09:03:21 PM
Among the reasons are tether length, mounting point, type of chute (ribbon, tri-form or cross-form) and how the air comes off the car.  I'm sure there are others, but that is a good start for a list.
