Spirit of South Dakota Lakester
Started by Tman, December 31, 2010, 01:49:36 PM
Jon
If you draped that in one bit and only got 2 wrinkles you have to be happy.
Is that the finished size or a mold that your making Tman?
cheers
jon
Underhouse Engineering
Tman
#301
Hoping to just do a couple splashes off the plug. No mold. We will see. You can see a right-left line towards the front where I cut loose a piece of mat and did it in two pieces. Looked like I could have done it in one and hindsight says I prob could have but I have no clue what I am doing save for a couple write-ups I have read here and the notes on the can of Resin!!!!!!
Jon, the next layers will be done in about 8" wide strips and layed up criss-crossing in diagonals unless someone tells me a better way?
Jon
The only fiberglass attempt that hasn't caught on fire is the body plug in my build.
I bought a book off fleabay that I read.
I drape the cloth dry until I'm happy with it.
I got a roll each of 0/90 degree and 45/45 degree and was planning on alternating layers.
When I was happy with the cloth lay I just started at one end wetting it up with a dabbing action with a 1" brush.
Apparently any more resin than just enough to wet up the cloth is just adding weight and no extra strength.
Cheers
jon.
Tman
First layer ended up being 3 wrinkles. Got the second and third done tonight.
38flattie
Trent, I'm curious as to how you decided on the nose 'cone' shape? The sides all appear flat, and I would expect a cone, or bullet shape- of course, I know didly about aero though!
Is this a design you liked, copied of off another car, was suggested to you, or.....?
The build is looking good!
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
Tman
Quote from: 38flattie on April 02, 2012, 04:36:23 PM
I answered you on the HAMB as well. It deveolped after looking at several cars and such. Shape started as sketches and evolved from there. Yes, the car is rather flat sided. It will run on the ground and be flat bottom.
55chevr
Tman
#307
Quote from: 55chevr on April 02, 2012, 05:06:17 PM
I like it ...
Thanks Joe, did some trimming and it looks good. Only 1/3 to 1/2 the layers I need. How thick SHOULD I make this thing?
Last picture, below, is taken from 3" off the deck. This is full on frontal.
Tman
Looks similar but I am up to 3 or 4 layers on the nose. Fighting a cold so the fumes are not bad! Wonder how many layers it takes til I get the right thickness? I feel for Jon and his streamliner! :-o
55chevr
criss cross the layers and it will stiffen up ... thickness not as critical as stiffness ... you will feel it ...
Elmo Rodge
Tman
Getting there, a good day of Rockies Baseball and laminating
When it is thick enough to sit on without buckling it will probably be enough
What is your B/L ratio?
(unfamiliar with this fiberglassing term?  Beers to Layers)
Tman
Quote from: Stainless1 on April 16, 2012, 07:47:08 AM
B/L=5, I think.........................
Right now it is about 3-4mm thick at its thickest. Got a ways to go.
Jon
Looking good Tman
How much support will it have?
Are you putting the cloth on at different angles between layers?
What weight cloth are you using?
Mine is quite heavy, will try and find the invoice.
Cheers
jon
