Spirit of South Dakota Lakester
Started by Tman, December 31, 2010, 01:49:36 PM
Tman
I will start with a thank you to all the help and advice so far. You folks are great. I will flesh this out a bit more with details as I have time and the car evolves. I do have some sketches, measurements, many notes etc.
This first set of pictures show the plug going together over the holiday break. Going off my sketches I decided I needed to build the foundation (frame) around the final look of the body. This way I am not trying to skin a chassis that was put together with no parameters.
The four above shots show the first shaping. Blue foam laminated with silicone, shaped with an electric chainsaw and cheesegrater
The two above show laminating extra material to get teh shape closer to my template
Last 3 above show me starting out with Rage Filler that did fine, did not attack the foam, but my hardner was bad. Decided after talking to a fiberglass pal to just use drywall mud to get the shape roughed in. Way cheaper than Rage!
Tman
More detail. Along with the chainsaw for rough shaping one picture shows a Japanese Pullsaw. This is by far the most versatile tool in my shop! Use it for fine woodworking and many more uses. This one is my first, an Irwin. Kinda cheap, I will upgrade to a nicer one for my finish carpentry after beating this one up on a Christmas Tree and foam :-o
I started this part over Christmas when I could not buy the steel. Had a plan and some scrap blue foam. Used 3 different types of silicone/caulk to glue em together. Again, what I had. Used Big stretch, Some chimney silicone and basic Painters caulk. My hot glue gun was too smalll but showed priomise.
As for the car, those that have been in the chat and talked to me on the HAMB know we are doing XO/GL to start. My partner, Tom is into inliners. The plan is to build a well-built car that we can cut our teeth on while working up the CID for faster XO engines. Starting with a bored out 235, plenty of room to grow in XO.
On the advice of others and my own ideas, the car will be setup for anything from a small V6 up to a Jimmy in length giving us many choices down the road.
Any questions, thoughts or input is appreciated. We are new to the LSR world.
Thanks, Trent
Dynoroom
Glad to see you moving forward with this project Trent. Can't wait to see how your build goes.
Tman
Thanks man, doing all the behind the scenes legwork right now, I always feel better on a project when I haul the steel hom and set up mu frame jig.
Buickguy3
                   [America]
panic
Like to hear some details on the 235?
Tman
Tman
Quote from: panic on December 31, 2010, 09:01:01 PM
If you are the same Panic that has been banned from th Jockey Journal, the HAMB and other forums I dont care what you wonder.
Tman
Quote from: Buickguy3 on December 31, 2010, 08:52:00 PM
Are you looking at XO/GL, or XO/BGL?
Our first goal is XO/GL Sorry I was flippant
Thanks Tman---the LSR comunity is a little small for very much trash talking.
panic
What a charming remark, and an excellent way to solicit helpful comments.
I'm sure your competence is equal to your manners (6 posts, 2 insults = 33%).
debgeo
George---Sidecar in progress
ironwigwam
Panic isn't it about the time you delete your posts and runaway.
panic
I'm sure I speak for everyone in thanking you for your valuable contribution.
(if anyone is curious about his preference for rude behavior instead of actual dialogue, I'll be happy to explain it privately)
Now, now, now, guys.  Open discussion and disagreement is fine -- but let's please keep it on a level of  plain disagreement and not tending toward name-calling.  It's the first day of a new year -- let's please try to keep things on a pleasant keep this year.
Thanks.
