UK Lakester build G/GL
Started by Lemming Motors, January 11, 2018, 04:43:42 AM
Lemming Motors
The headers are in Irvine Ca - the company I work for has an office close by and I used to go there a few times a year for business. I started this dialogue something like a year ago and took over my ITBs to match to the head (US sourced) and a pattern for the relationship of the engine exhaust system to the bodywork (for fit).
I don't get out there anymore so I wont be able to smuggle these back in my luggage.  :cry:
The exhaust shop there has been into racing engines for the last 30 years or so (and does fast street cars etc as well) and he knows his way around the engine I am using so it seemed sensible at the time.
Just a squeeze.
Lemming Motors
Prop shaft containment: check.
Just a squeeze.
Lemming Motors
One last tubey pic since you've been well behaved.
They (it is multiple tubes but a single assembly - they or it I wonder) should be in transit soon. Oh how I pray we got the pattern right  :roll:
Just a squeeze.
ggl205
Truly beautiful, John. That guy does amazing work.
Elmo Rodge
OK. Who did the headers?
Wayno
Lemming Motors
John Grudynski
HyTech Exhausts, Irvine Ca.
www.hytechexhaust.com
Just a squeeze.
Lemming Motors
Back on page 34 of this thread was a discussion about fire bottle orientation (ideally bum forward) and the firing pin actuation of the bottles that I have.
In the following pics the bottles are sitting above the chassis assembly that surrounds the rear axle and prop (drive) shaft and the front of the vehicle is to the left.
The other pic shows an alternative cable actuation lever that I made from some 6mm aluminium (aluminum) plate. I can now 'pull' and with a small inclination of the bottles the assembly will clear my transversely mounted coil overs. I also 'pinned' the plungers so the levers cannot fire the bottles in transit or when working on the car.
Result.
Just a squeeze.
Elmo Rodge
Cool. I'm working on a bell crank setup for mine. My bottles are transversely mounted and one requires a blister to keep it out of the airstream. When I was building the car none of the suppliers could tell me how far everything stuck out of the top of the bottle. That was not helpful.  :-P
Wayno
Lemming Motors
yup, from the bottle opening to the end of the actuation mechanism is a lot further than you expect with this set-up. Thats the main reason I was contemplating nozzle for wards originally but I think I am on the right track now.
Just a squeeze.
kiwi belly tank
Obviously the horse has bolted here Mate but centering the pinion & cutting one side is desirable to not have excessive U-joint angles with a short shaft.
Lemming Motors
Sid
At least now if the UJs cry enough the resultant bid for freedom will be contained.  :laugh:
I can?t be the only one with a short shaft on a steep angle?
Just a squeeze.
kiwi belly tank
U J's speed up & slow down twice per revolution & the greater the angle is the bigger that problem becomes. This usually creates a harmonic vibration that is somewhat absorbed by the shaft tube but a short shaft & high rpm multiplies the problem. Other than the risk of scattering a shaft, trans or diff parts, this is all sucking up horsepower before it comes unglued.
"I can't be the only one with a short shaft on a steep angle?"
Sounds like my excuse at age 13.
Would using constant velocity joints help?
racergeo
    Oh, Stan  Stan Stan. Keep em coming!!!  And yes constant velocity u joints :lol:
