UK Lakester build G/GL
Started by Lemming Motors, January 11, 2018, 04:43:42 AM
Lemming Motors
I have a question about nuts please:
Rule book 2.G says 1/2" wheel studs with 1" lug nuts. I am using steel wheels (stock) which I assume are a 60 degree interface but all the 1" wrench size lug nuts I have looked at (Jegs, Speedway etc) state they are 45 degree for racing wheels.
Am I misunderstanding the compatibility?
Does anyone have a supplier for a 1/2" thread lug nut (1" wrench) for stock Chevy steel wheels - can I use the 45 degree ones or is that a no-no?
Just a squeeze.
If you can't find them, anyone with a lathe could change the angle on the nuts rather easily. those nuts are a pretty good size so there should be lots of material.
Lemming Motors
Thanks Pete, good call and that is now my back up plan.
Hopefully it wont come to that (importing nuts then machining them) - I am hoping there is a source of compatible ones 'off the shelf'.
Just a squeeze.
Lemming Motors
Sourced the wheel nuts and the angle is being altered to align with the road rims.  :-D
Aw chute, today is my last day of work. Not a victim of the virus but of corporate greed (well, an acquisition which is sort of the same thing).
Tomorrow I start gardening leave which, in my case will be a mix, negotiated with the steering committee, that includes the garden, diy and the garage.
Recent progress pic attached (for the pun value).
Just a squeeze.
Lemming Motors
Fooling around with the front suspension at the moment.
4 bars mocked up, steering rack mount to the axle and the shock actuation (location = above the drivers legs) in mock up, seen here.
If the stars align the entire chassis and all of its critical bracketry will be ready for a welding session in a couple of weeks.
Just a squeeze.
Lemming Motors
The chassis is upside down (hope that doesn't happen too often) and that allowed some proof of concept work on the sliding block for the front axle lateral location.
The rod end / turnbuckles are there to reinforce the guide tower both laterally and fore / aft.
The block pivot 'bolt' is 3/4" thick threaded at one end so it screws through the 5mm plate to a captured 3/4" nut and turned down at the other end for the 1/2" locating / lock nut.
Just a squeeze.
ggl205
John:
Is there going to be a bearing in the block?
Lemming Motors
John - not in the plan - I am aware Alfa did incorporate one in their GTA rear axle set-up.
I figure it can rotate on the 3/4" pivot and its not designed to do large mileage or very much suspension travel / movement.
Just a squeeze.
John,
The slider block is brass  (or bronze?) that is a bearing. Love to see a good sliding block locator. Great job John!
Lemming Motors
Thanks Rex and yes, good point, the brass will act as its own bearing for my purposes.
I am not sure if it is a 'good' sliding block locator but it is at least a sliding block locator with limited space for watts etc. in my application and might be food for thought for others.
Lets see if the car tracks straight before giving it an unconditional thumbs up though.
Just a squeeze.
Lemming Motors
The full chassis incorporating the previously completed roll structure has gone away for a welding session by someone who has a better strike rate than I do (some of my welds are gutter balls - I just don't have the art).
I decided to finish up the pedal assembly today; clutch foot rest (adjustable), throttle return spring #2 plus the throttle stop (adjustable) and a floor wedge (to be covered with anti-slip) for a heel to push against when bailing out.
The entire pedal assembly can be moved for shorter legs than mine by around 5" so the clutch and brake masters will need flexi lines on them (with stainless over-braid) - any reason why I shouldn't run that stuff all the way thus avoiding joins from flexi to hard line and back to flexi to attach to the slaves? I am thinking a 1.5" x 3/4" channel running under the floor for the wires and pipes to run in - punch that through the firewall and liberally seal it with intumescent silicone?
Just a squeeze.
I wouldn't recommend doing that. Flexible hose lines don't have enough rigidity to prevent expansion under pressure. This results in a "soft pedal" feel.
ggl205
John, what size master cylinder are you using for the clutch?
John,
I have worked on cars that used -3 stainless flex line from the master cyl to the brake(s) it was a road race car, and there didn't seem to be a problem. On the other hand you "should" be only using the brakes once the parachute has gotten you down to "slow" so brake use is pretty light and even if you should loose your chute you will have lots of room to coast down. Do not use -4 that will make the pedal soft. Use -4 for the clutch circuit.
We use flex lines on the bikes.  It is the typical line.  There is a big difference in response when different line materials are used.  The softest and spongiest response seems to be with the rubber lines and the opposite using the teflon tube with braided stainless steel cover lines.
