UK Lakester build G/GL
Started by Lemming Motors, January 11, 2018, 04:43:42 AM
Lemming Motors
Thanks Jack
I will look into that - not sure of the numbers yet.
There is nothing interference sensitive going south as the ECU and all its bits will be in the engine bay area if I can find somewhere nice and cool for it.
Just a squeeze.
Lemming Motors
Have I understood this correctly?
I am routing the mechanical chute release cable and since the tube is there and I have the end cover (triangular hanky thing) and the sprung pilot jack-in-the-box I thought I might as well mock up the release mechanism.
I assume more compression on the pilot means more oomph on release but this seems to put additional tension on the release rod / mechanism and it becomes more resistant to release - I guess there is a happy medium but broadly speaking do the pics suggest I am on the right track?  cromag
Just a squeeze.
Lemming Motors
And yes, I bent, re-bent and generally beat on the steel loop on the end cover so that needs replacing before this gets used in anger as that is a potential failure point - oops.  :cry:
Just a squeeze.
kiwi belly tank
That style is always going to load the release cable by wedging the buckle between the pin & loop. Lessening the pack pressure to ease that problem is going to reduce the pilot launch speed & distance & that's never desirable.
If you machine up a little cone that the buckle eye fits over, mount it with a single countersunk Allen bolt from the inside of the chute tube, that will help unload the release cable. The end of your cable is kinda fat, what is the reason for that? A solid stainless cable works well with this setup, I've done a few this way for other people. A little more length would be desirable to prevent any unwanted releases as well.
Lemming Motors
Thanks Sid
The cable is a redundant 32C morse (push pull) that I had 'in stock'. I simply ground the threads down a bit to mock up this assembly. It is not the finished article.
Length noted (a little more is always desirable). Simply a matter of where I taped things on.
I can visualise the cone but I am not sure why it would load up less than the loop as pictured?
Just a squeeze.
kiwi belly tank
It's simply a matter of load per contact area & angle. Get the buckle eye on the cone so it's snug then the load contact area is half the diameter & you'll see what I'm talking about. Also round off the sharp edge of the eye hole. Make up a simple test rig on the bench so you can mess with it for the best results without carving on the tube.
Interested Observer
You might consider using an over-center or almost over-center type latch to carry most of the chute retaining strap load, with the release cable only needing to release the latch.
ggl205
John, when it comes time to deploy the chute, you will not be gentle.
Lemming Motors
My primary is a switched solenoid so I want it to be 'light'. My backup is the ejector seat release handle and that is intended to be only for the 'Houston we have a problem' back up plan, and then it will not be gentle, correct.
Just a squeeze.
Building in some additional length of the tube is a good thing.  Years ago, when the roadster was new, the chute barely came out of the tube and then wouldn't blossom.  Lots of dead air behind a real Street Roadster.
Bob Stroud came thru with a longer main line and more spring pressure.  It wouldn't fit in the existing tube, so we had to take it out and lengthen it.  If it still comes out lazily, you can easily fill in the front of the tube.  The way it is now, you wouldn't want to stand behind it.  It takes at least two people to load it.
John Burk
ParaGear site shows "CONE, SMALL CONTAINER LOCKING - 36B6229" in 3 sizes . Chrome plated so the buckle slides off easily . Perimeter holes to rivet to the tube .
kiwi belly tank
Good one John! :-) I made my first one like this 30 years ago & they work the best for this type of release.
http://www.paragear.com/skydiving/10000176/H439/
Lemming Motors
Thank you for the info and direction; will get some cones made and play some more.
Lively pilot ejection noted. I was experimenting with the tube vertical and at one stage he was leaping out and touching the garage roof. I drilled two holes near the exit end 180 degrees to each other and fitted a ca. 1/8? rod to hold him down while the end cover was latched, then withdrew the rod to load the pilot against the end cover; that was a big improvement for loading.
Just a squeeze.
Lemming Motors
About to start wiring the dash: I decided to repaint the instrument pod and match the cockpit inners to go all warbirds on it.
Just a squeeze.
Where did you get that Made in USA gps speedo?
