TREITS STREAMLINER
Started by Freud, July 21, 2009, 12:36:25 PM
Refer to the last post on the previous page.
Last two files. Explained in the above post.
The three rollers for the tail section carriage are now visible.
hitz
Freud,
  *? I knew that would happen if you kept covering this project. We all appreciate your tenacity!
  Harv
I take medicine for my tenacity but it stays the same size and always points to the South Pole.
Hume is the one that needs the tenacity.
Dr Goggles
Quote from: Freud on October 15, 2009, 04:23:42 PM
and long may it point that way......just while we're here , you haven't thought of trading up to an eleven-acity?...them's the latest thing..... :wink:
It makes it hard when I try to deal with odd numbers.
Nexxussian
No odd numbers huh, bummer.
FWIW when I was at speedweek I stumbled through a shop somewhere in Wendover (or was it west Wendover, I forget  :?) and I could swear I saw an audio mixing board for sale with the pots labled in increments all the way to 23. :-o
'Goes to 11' Ha! :roll:
Thanks for you 'acity' be it ten, eleven, or even 23. :-D
Just happy to be here. :-D
Erik
bvillercr
Freud, keep the info commin.  Can't wait to see more. :-D
I'll see what I can add Friday.
FerD
Dr. F,  Glad to see you are up to your usual STUFF!!!!!!!!
I try to keep these fotos in the proper chronological order. With Speed Week and Gas Up, Ive sorta mixed
them up. These were shot before the last two posts. Just look at them and it should fit together. If "a picture is worth
a thousand words," these will save me a lot of writing.
More image.
Last of this set.
I'll shoot more on Monday. If it gets redundant I'm sorry. I can only show what's done.
FREUD---thanks for the efferts and the photos    :cheers:
As I scrolled through the files I found these images of an adjustable fixture to hold any panel  as it is finished.
Notice the sliders on the tubes that allow the adjustments. It can also be adjusted for any angle to allow access to the
inner portion of the panel.
It's MILLER Time.
