TREITS STREAMLINER
Started by Freud, July 21, 2009, 12:36:25 PM
38flattie
 Fabulous craftsmanship, cool technology, and a very well executed build
thread-Kudos, guys! :cheers:
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
When we quit posting daily on www.target550.com at the end of the year, Ray Therat must have had too much time to spare.
He redid the presentation of the thumbnail images and they look excellent. To change from one image to another, click on the
thumbnail on either side of the main image.
The first presentation for 2011 is in place.
http://www.target550.com/gallery/86_plumbing_hoses_jfcracing_first_conference_2011/index.html
Besides images of the hoses related to the oil system we included a link to the company that made them.
www.jfcracing.com     is a racecar rebuild and restoration company. Their site represents them exceedingly well.
The hoses come from a need that they experienced and they solved it by putting in the equipment to make their
own hoses for their specific needs.  They are knockout and we appreciate their products and their excellent service.
So here's our first of many displays for 2011. I'd love it if the construction portion is completed this year.
desotoman
When I was at Hume's shop today the door opened and Frank Martinez walked in.
He was looking at some parts that need to be duplicated in composite material.
As the chat progressed Hume asked him if he knew a certain fellow.  Yep, he did.
Seems that Hume worked only several buildings away from Frank in the Valley,  a  l o n g  time ago.
There must have been something in the air that developed these craftsmen cause a lotta  them
just happened along in that era and that area.
New post today on www.target550.com.
It covers an alteration to  the water tanks, Jason and the rear panel finishing and Frank Martinez.
The url is :   http://www.target550.com/gallery/87_altered_water_tanks_heater_elements_composite_parts_panels/index.html
Enjoy.
Freud,
A comment on the tank heaters, it is acceptable to run the heater element in direct contact with water but I highly recommend that the element for the oil be in some sort of "well" which is typically a piece of tubing welded into the oil tank that the heater mounts into. Not knowing the watt density of the heater but assuming that it is high enough to heat the oil to operating temp relatively quickly so it is probably pretty high. What can happen is that the temperature of the heater right at its surface can be high enough to actually burn the oil and this will ruin the oils lubrication abilities. By using a well the same amount of energy is transmitted to the oil but over a larger area at a lower temp and you can prevent burning the oil. This is one reason that I prefer the external heating pads that can be wrapped around the outside of the reservoir.
Just my 2c.
REX, I always respect and appreciate your suggestions.
I'll forward this to Marlo and Hume.  It will be their call but I assure you, they will take it into their conversations.
This build has been ongoing for a longtime and things have changed. This principle has likely been known for longer
than the build, but if they decide it has merit the changes will be made to accommodate the sleeves.
It seemed to me as if the "oil warm time" , on the lakester,  was rather long and the quality of the oil was not compromised but I'll make
certain that they are advised.
Thanks for watching our backside.
Will I be able to meet you at the SCTA Awards Banquet?
It didn't take Marlo long to answer:
This was his reply:
Yes, you are right, the element cokes oil on it if the element is not treated and also we only run 600 watt heaters. 2 of them.  The heaters shown are water heaters and we do run them direct.  We also preheat the oil with a space heater if required time wise.  Yes, to heat 10 gallons takes a while and we do it until we get enough temp that the oil flow will not be a problem.  The smallest detail can be the most important.  I do not like to have the heater in a tube as the outside of the tube can also coke.  This way, we can pull the element when the oil is drained and look at it.  Two 600 watt oil specific heaters per tank.
Thanks for the eyeball.  We need it.
marlo
We appreciate the comments from the builders that follow this diary.
Dean Los Angeles
Some general questions. How many hours a day are the guys working? Days per week?
What are the total parts that will be composite? I have noted several through the diary and was wondering the total.
I would SURE like to see a web cam in the shop so that we can drool 24/7.
Tman
Yeah, a webcam would be wild. LSR Porn for car folk!
Dean the way I see it is that the front wheel fairings, now they are each in 3 pieces, and the rear fairings will be composite.
I know on the front that there is the piece in Frank's hand in the www.target550.com website, post 01-08-2011, image 087_007.
Then, as I remember, the piece behind the wheel will be two pieces. I suppose you may be able to answer your own question if u
go back far enough in one of the two build diaries.
In www.target550.com the post of 11-26-2010 has shots of the front fairing. Go to image 072_08 and you can see the split down the length
of the fairing. The two pieces attach to different parts of the car. One to the belly pan and the other to an outside  panel.
The rear fairings have not been designed yet so I can't comment on them. I can say that in www.target550.com the post of 09-10-2010, images 057_01
thru 057_07 shows the method that the rear fairings will be designed.
As soon as the front pieces are formed I will show them. There will be aluminum ones formed for the rear and they will be the male molds.
Jason has most of the rear panels finished. When they are ready to be attached the work on the rear fairings can start unless some
other portion takes priority. In the post for 01-15-2011 on www.target550.com I will show some detail information on the panels that cover the rear wheels.
Work is at a stand still on both sides until several small pieces come back from the anodizing shop. They will be riveted in place and then the panels can be finished.
In a week there are 12 man days of work unless the weather makes it difficult to get to Humes. Jason lives in eastern Washington and has to go
over 4300' Stevens Pass. Snow has no respect for the Treit/Davenport streamliner build schedule. Sometimes Jason gets to work a little late following
his weekend at home.
If you want to watch a webcam 24/7 go to www.phoebeallens.com. She built the nest and incubates the eggs all day every day.
Don't hold your breath for a web cam in Hume's shop. If they ever install one I'm done doing fotos. I want no one to see how inept I really am.
Thanks for following this project and thanks for asking realistic questions. We appreciate the interest.
There is a chance that we will have a question and answer session by the build crew of this car at the Bonneville NW Reunion, Friday night, Feb 18th at
the Shilo Inn, Portland Airport property.
Check www.bonnevillenwreunion.com for the activities.
"If they ever install one I'm done doing fotos.  :cry:  I want no one to see how inept I really am'.  :-o
My ASCOT!!!!!!!!!!!!!!!! :x
I finally got in gear and did the post that I hoped would be done Friday.
The Bonneville Northwest Banquet too my time and I screwed off on the post.
I finally sent it to Ray Therat and he had his part done in a blink.
Here is the url:         http://www.target550.com/gallery/88_inside_detail_of_body_panel_&_special_screws/index.html
I showed a lot about the inside structure of one of the skin panels and an expensive screw.
Thanks for your interest.
There will probably be a mid-week post this week.
The Rat has something hidden away and won't share it with me.
RayTheRat
As Freud prophesied, I have a mid-week surprise.  Jason sent me some photos of "the master practicing his craft", that is, he shot photos of Freud while Doc was shooting photos of the liner.  Jason said he didn't get much co-operation, but I think Doc was just "in the zone," getting the great photos he provides so frequently.
In this post, you'll get a look from the other side of the camera.  Btw, Doc has a new Nikon 700D that's just fantastic and has such a sensitive sensor that he hasn't had to use a flash at all.  He asked if it made me consider switching camps...from the Canonites to the Nikonians.  If I had unlimited funds, I might consider it...but since I don't...well, I'll stick to my guns (cannons...er...Canons)  But that Nikon sure does a great job...as does Freud.
I hope you enjoy a different look at things.
http://www.target550.com/gallery/89_freud_at_work/index.html
Ohh...as I wrote on the index page, there are no captions with the individual photos.  It has more to do with the size of the images than anything else, but I think they're pretty much self-explanatory.
