XXO/BVGC '38 Chevy Coupe Build
Started by 38flattie, July 21, 2010, 06:34:16 AM
Quote from: manta22 on April 03, 2013, 06:38:10 PM
Quote from: saltwheels262 on April 03, 2013, 05:03:37 PM
the only bastard size thread that I can think of for a Harley
would be 1/4-24 .
it was used for securing lifter blocks to the engine case
and on ( I think ) oil pump studs to the engine case.
also, maybe more apps to the engine .
1/4-24???????????? Sounds like they couldn't decide on a 1/4-20 or a 1/4-24 so they took the average between the two. I've never encountered a 1/4-24.
Woops-- make that 1/4-28
pops29
  It is a 9/32 - 32   dam close to .8 pitch --  I did the cardinal sin " assumed " metric after I put the calipers to it. I re-checked it this morning with the mic. and a 32 pitch gauge.     Thanks for the input guys !!!!!!!!  :cheers:javascript:void(0);
RichFox
Interesting lifter arrangement in a Bantam.
pops29
  This is basically what I am doing less the bushings.  Thanks for the pics   it is helpful
38flattie
Rich, interesting that the Bantam has almost exactly what we imagined! Guess the idea wasn't original after all!
Fron Don this morning:
Here is the final fit.. Valves adjusted and adjuster locked down using standard 7/16" wrench -- tight fit - But I know Dale should be able to get a good fit at final assembly. So I am off to build the Real parts !
Randy and I met at John K's today, and the spoiler is done and mounted. John and I will meet in the morning, to get the spill plates installed. John has done a great job on the aero mods, and Randy is an animal when it comes to fabbing and installing stuff!
Don, Randy, and John- Great Job!
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
38flattie
Adjustable spoiler is on, and spill platesill be added in the morning!
38flattie
Spoiler and a little front end progress!
Wow, talk about transformation... looking good Guys
Buddy, see you soon, let me know
Buddy wearing a formal shirt?  Must be a big occasion.
38flattie
Stan, I guess someone forgot to tell me that a black tee wass formal! :-D
Spill plates are installed. John now is going to make the pieces that go from the spill plates to the body.
Elmo Rodge
Buddy, it's not that it's black. It's because it has sleeves.  :cheers: Wayno
Tman
Quote from: Elmo Rodge on April 07, 2013, 02:33:43 PM
Maybe it was sleeveless but still had a collar?
38flattie
Quote from: Tman on April 07, 2013, 06:19:14 PM
C'mon guys! Everyone knows the sleeves get cut of at 70deg, the collar at 75deg-I'm not a total barbarian! :-D
Frankie7799
Looks like a Pro-Mod now  :-D Great work
