XXO/BVGC '38 Chevy Coupe Build
Started by 38flattie, July 21, 2010, 06:34:16 AM
desotoman
Quote from: 38flattie on October 10, 2013, 01:06:48 PM
looks like they are from Jalopy Journal?
Nope, I copied them from POPS post on here. I use Firefox and can see everything fine.
Re: XXO/BVGC '38 Chevy Coupe Build
« Reply #2080 on: October 09, 2013, 10:15:43 PM »
Rich, you're magic. All is exposed. Thanks!!!  :cheers: :cheers: :cheers:
Frankie7799
Ouchie! Hopefully Donovan can repair the gear drive for ya Buddy.
I found the posts without photos that used to be there.  For anyone else that is/was clueless, look around post #2060 in this thread.  I don't know why they're not, either, but'll take a gander at why.  Unless you tell me that it isn't worth the bother now - that enough has been seen, or that they've been posted again.  Let me know, hey?
pops29
Wow --  I guess I know how to gather a crowd    -- lol   :evil:
  I am not the best at posting but I did do it like I did in the past and I could see them fine--- any help on posting in the future would be great.
Roseville Carl
Hey Don with your skills don't worry about pics....... just keep on keepin on!!!!!! :-D :-D
"Keep Em Between the Whites"
and yes Virginia the world is indeed Flat
38flattie
Quote from: pops29 on October 09, 2013, 08:15:43 PM
Ok The mystery is solved !!! I tore the front timing cover off and I found more crushed up steel
So as I was looking around at the parts I removed and
I found where the pin came from
this is an anti-rotation pin for the idler gear shaft.. What we think is we started to lose the bearing and the shaft rotated and sheared the pin. We will now look in to the oiling system to the front of the cover
Donovan says this gear drive will only fail if something runs through the gears. They also say, that nothing of the gear drive would break and run through the gears, and it must have been something on our end.
REALLY? :?
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
DND
Maybe your unit had a out of round gear like I talked about in post # 2078, and that killed the idler bearing
If you have no ' clink - clink '  in the gears 360 something has got to give, either the ball bearing or the cam bearing
G Don
38flattie
Don, something was definitely wrong, and we need to get to the bottom of it.
I haven't seen it in person yet, but will next weekend.  Just theorizing, I wonder if we are getting oil to it? With the dry sump, and no 'splash' oil, it's possible it doesn't get enough.  At the very least, we'll add a couple of spray nozzles in the cover this year.
tauruck
The nozzles won't hurt and you'll be more at ease. I really hope you find the problem.
pops29
Well, Buddy and I finally got together at my place this weekend to do the tear down on the motor ,, here are the results ..
well it looks as after a few self inflicted wounds,(( cracking of the block, head gasket issues, and edge clearance issues on the main bearings )) the motor held up fantastically . All the bearings look great, the scoring in the cylinders can be honed out. ect.
as for the self infliction -- the Block was looked at by the owner of lock-n-stich and he explained the process of the repairs to the cracks, and we feel this is the way to go. I will see if we can get some progress pictures of the repairs and post them. We also spent some time with Kenny Boyd at his shop to look over all the parts and he was impressed with the condition of the parts so we will proceed with having the block repaired, then to Kenny's shop for pressure testing the block, clearancing the main bearings, honing of the bores and lapping the valves. Buddy is working on ordering new coated bearings and new rings.
Here are the pics
cam held up great with the new roller lifter setup as did the lifters and blocks
pops29
now for self infliction !!!!!! we scored the top edge of 4 pistons on one side of the block by not having the head gasket aligned correctly you can see the interference in the pics
pops29
here is a few shots of the crank
pops29
#2098
All in all this was great news !! It shows this motor can take the abuse of the SHIFTING GURU BUDDY  :-o and stay together. :cheers:. This year we plan on a bunch of changes, all in the small details,, areo, complete electrical re-wire (( thanks to Bob at Rebel Wire our newest sponsor )), fabrication of new exhaust system ect.
pops29
Maybe, I should have said SHIFT MASTER BUDDY  :-D
