XXO/BVGC '38 Chevy Coupe Build
Started by 38flattie, July 21, 2010, 06:34:16 AM
pops29
Yes the balls do the swedging  the jig is also setup for locating and drilling out the axles   it works very easy
38flattie
#1816
Quote from: Jack Gifford on June 21, 2013, 10:39:06 PM
Ron Iskenderian sold me EZ-Roll wheels and axles- I'm surprised you couldn't buy them.
Apparently the Harley axles are not hardened on the ends, to allow swaging them over? The Isky axles are that way- I'm just trying to figure a way to emulate the factory's coining dies that do the swaging. I'm thinking of a jig that will resemble the tool you pictured.
Jack, you must be better connected than me!
I talked to Ron Iskenderian twice, and also Wayne Jesel-they both blew me off! Luckily, when I need parts for other builds in the future, neither company sells anything that I can't buy elsewhere.
You're welcome to borrow the tool, if you think it may help you with swaging your axles.
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
Wrenchbender
Hello folks here is a quick update on the flatcad sorry for the limited pics but I've been hammer busy doin a lot of things that are not really seen in pictures and to be quite honest I havent thought about taking to many anyways here are a few pics there has been a lot of progress on the car the front end fiberglass parts grille shell hood and stuff is all painted a fresh coat of bright red, the car is now at the paint shop (Liles performance and auto body) getting some body work and fresh paint job as well  we now have a full belly pan that I have fabbed up and am currently in the process of finishing i have also relocated the parachute to the trunk and made a new push bar that is shorter and lower so stay tuned this week there will be a lot going on and progress being made Chrome don't get ya home
38flattie
Outstanding work, Randy! The car is looking great, and I love the carboard fuel tank we mocked up! Don has it, and is working on the tank!
I cant wait to see the paint and new lettering job!
gkabbt
#1819
Buddy,
Wanted to add a little (very little) humor to you thread!  :-D
Sooooo, my wife goes out shopping Friday and comes home with this little trinket for me.
For years, I have used the expression, "When pigs fly out of my Butt" and she said she thought of me when she saw this.
As I was pulling it out of the bag, I immediately thought of you and told her what you have in your sig lines.
So, I present to you and everyone:
Piggy, The Flying Pig.....Protector and Defender of the Realm!.....LOL!
If Chris (Milwaukee Midget) can have a Traveling Gnome as a Mascot, I guess that Piggy will be mine.
Hope this brings a smile,
Gregg
Tman
Do I see the drip rails being removed? And did you guys make roof rails?
38flattie
Gregg, that's awesome! I need to get a smaller version, for a hood ornament, that I could take off at the starting line!
Trent, we did trim the drip rails. We had planned on adding roof rails , but simply ran out of time.
Roseville Carl
#1822
Dang Buddy she's lookin goooooooooooodddd
"Keep Em Between the Whites"
and yes Virginia the world is indeed Flat
Quote from: gkabbt on June 23, 2013, 04:29:08 AM
Buddy,
Gregg
Gregg, we'll get them together for a photo-op - right next to the Pink Flamingos.
So . . . Buddy . . . We're heading into dyno time, if I'm not mistaken.
What's the word on the engine front?
And by the way - what's the diameter and overall length on those roller rockers?  I might be seeing a British application in my future . . .
BoredAndStroked
Have been thrashing like mad to get the FlatCad assembled and ready to go to the dyno - worked all weekend and only have 3 evenings left to complete it.  I hope the Flathead Gods smile on me and allow me to continue without any unknown drama coming my way.   If everything goes like clockwork - I might just make it.   It is down to the wire.   To put this whole things together in about 40 hours of work is quite an effort . . .  I sure hope I can make it  (as I have a normal job too!).
Got the whole lower end, custom main caps, girdle, crank, rods and pistons in.  Chris Daniels has been helping out - without him, not a chance I'd have gotten this far.
Bearings - Some Unexpected Goodness:
A good thing happened, but only because I screwed up on a part number that I gave Buddy for the main bearings.   When you have a billet crankshaft made for a 'normal' engine like a BBC, you'll have 1/8" radius fillets on all the journals - for strength.  Due to this, you normally run narrower 'N' bearings (so they don't get pinched on the fillets).  Last year we just ordered the normal Clevite V-Series mains - with the N suffix.   I didn't even think about it.
BUT - when I gave Buddy the part numbers for bearings this year - I forgot the 'N".  As luck has it, we don't need the narrow bearings on the flatcad as the journal widths are about 1.250 - much wider than a BBC, so there is room for the wider bearings . . . and they are 11% wider - which is a lot more bearing surface (with 3 mains, we need all we can get!).   Cool!  :rolleyes:
ORings:
As we're going to have higher cylinder pressure this year, we decided to redo the ORing setup - we now have stainless O-Rings in the heads and a receiver groove in the block.  The grooves in the heads are .030 deep and .039 wide - we'll have a .041 stainless wire pushed into them.  The block has a .010 deep receiver groove that is .0625 wide (it is centered on the head rings).
Mains:
Don and Kenny did one hell of a job on the new lower main and girdle setup.  We created a splayed center main cap to replace our square one from last year and also a wider front main cap that picks up the sides or the block.  Also, Don added dowel pins to tops/bottoms of all caps.   This is about as strong as we can make it.   Lets hope the lower end stays together.
Pistons:
You'll see the purdy coatings on the tops, dry film on the sides and a heat shield coating on the undersides.
Rings:
We're running Akerly/Childs HTD 'hellfire' style rings.  1.5, 1.5, 3.0 mm stuff - all from late model Ford mod motors.
To follow are a couple posts with a bunch of pictures from when the block came home earlier this week and during the assembly process - enjoy:
Member of FlatCad Racing Team - 2011 - 2025
Goal:  Have fun, make friends, be safe - learn as much as possible, contribute when I can and hopefully see this beast of a Flathead Cadillac go over 200 mph!
BoredAndStroked
More Stuff:
BoredAndStroked
More Stuff:
BoredAndStroked
Lastly - Slugs in the Holes!
onward---onward---enough to earn the right to have a pig with wings for a hood ornament!!!!!!!!!!!!1
Quote from: BoredAndStroked on June 23, 2013, 05:50:39 PM
ANYTHING you can do to spread out and even up the loads is going to make a difference.  As long as you're not pinching on the fillet, that IS good news.
Don't let the deadline cause you to cut corners - and I know I didn't need to say that, but it's just SO DARNED EASY to skip a step when you're trying to make a deadline on the down-hill.
Best of luck on the dyno - and don't throw it all away in the bull pen.  I expect to HEAR this thing this year!  :wink:
