Australian Belly Tank
#4860
stretch the tongue   it is much easier to do  :-D
on the v-7 and v-6  just pull the push rods and make air springs out of the dead holes  should have way less than 1% parasitic loss
A test mule motor is a real hard engine to build.  It needs to provide consistent performance throughout the test session.  Otherwise, the motor degradation fouls up the test results.  It is hard to differentiate between motor problems and tested component issues.  The Duttweiler shop knows the Chevy engines well.  Logic says their mule motor might be a good build.  This one survived just under 200 dyne pulls without performance degradation.  A link to the article www.hotrod.com/how-to/engine/hrdp-0162-engine-coatings/  It is bigger than 300 ci.
Dr Goggles
Hmmmm, Duttweiler........
Stand by men, there may be an announcement shortly  :wink:
Dr Goggles
Quote from: Rex Schimmer on January 05, 2016, 12:31:33 PM
Plus you would not have to buy a $1000 2 -9/16 stroke billet crank.
I knew it!
Rex, you're living in the sixties. :cheers:
grumm441
Quote from: Dr Goggles on January 05, 2016, 09:28:33 PM
:cheers: :cheers: :cheers:
Dr Goggles
To be honest you, the Reverend and I need to find breweries with handles on the side of them, not just steins....
Be patient grasshoppers.
grumm441
Dr Goggles
mmmmmmm
Reverend Hedgash
Dr Goggles
With a curve like that theoretically  at 8nfinite rpm it could make infinite hp..... :roll:
Quote from: Dr Goggles on January 05, 2016, 09:43:32 PM
I knew it!
And there is a problem with that??? Hell I was in my 20s then and everything worked!
tauruck
grumm441
Quote from: fordboy628 on January 06, 2016, 02:40:11 PM
Yes.    In theory only.    Even pneumatic valve springs have their limitations . . . . . .
Desmo
It's what I do
Use a blimp for a body instead of a tank.  There will not be all of these pesky issues with packaging.
