Australian Belly Tank
Dr Goggles
If we keep our total loss cooling system, of  60 litres (+engine cooling system cap.) is this the right formula to calculate whether we have enough volume?
Specific Heat Capacity (C_p) for water @ room temp is 4.1813 J/(g*K)
K is Kelvin
The equation is Q = m*C_p*delta_T, where Q=heat energy, m=mass of water in grams, C_p = 4.1813, and delta_T = change in temp in either K or degC.
for a safe margin of error lets say we are making 350Kw ( 470 hp) for 8mins. 60 litres, raising the temp by 65 degrees C.
Interested Observer
Dr. G,
As a check I converted to English units and did the calculation and got delta T = 1207 F = 652C.  Which suggests there may be a factor of 10 missing somewhere.
Also, the full horsepower is  not dumped into the cooling system, and 8 minutes seems like quite a long time for a run.  If one assumes 30% of the power and 2 minutes duration, I get 90.5 F = 32.5 C which seems a reasonable result and pretty consistent with prior experience.
Interested Observer
Attempt at engine photos:
Interested Observer
More engine photos:
Interested Observer
And the last---
Dr Goggles
#4925
Quote from: Interested Observer on January 17, 2016, 03:23:31 PM
Dr. G,
Of course, likely a run is in the 3-4 min range, just looking for outside parameters... I asked because when I took the capo off it yesterday it was STILL pressurized two years after it last ran so if it has enough capacity it may well be convenient to use it as it is.....the least attractive option is a fan blasting air out of the top of the car......
My calculations gave me about 50% too, though by slightly different means. :roll:
Polyhead
Why do fabricated valve covers always end up looking like the coolest thing in the world?  Just, nothing makes an engine look serious like fabricated valve covers.
Ben 'Polyhead' Smith
  KE7GAL
Dr Goggles
Quote from: Polyhead on January 17, 2016, 06:07:16 PM
yep, unlike billet they hint at mongrel :cheers:
............ and 8 minutes seems like quite a long time for a run.
You're right,it's somewhere between no-time at all and a lifetime.........at least that's what it seems like :wink:
maj
Our runs include driving back on the return road , which can be the cooling down period or the last straw
Lynchy
Dr G
What model is the Electromotive ignition? Big Gaz and I have both had Electromotive ignitions back in the 80s. If it is one of these I'd ditch it. They were great back then but basic these days. It's probably something a lot more recent than that... Motec is awesome but ridiculously expensive. Just the camera system in the Jag was $5k. The best system is one that you understand and can work with and have ready access to an expert.
Regards
Lynchy
Reverend Hedgash
Quote from: Dr Goggles on January 17, 2016, 09:30:40 PM
That's exactly what I thought. As soon as I saw them I thought that will look perfect in our tank. None of this branded mass produced bolt-on brightly coloured Speed Shop stuff! Made by hand, the weld line being the gesture of the artist that made it.
There is history in this car. From the first piece acquired being the bellytank, to the engine it is receiving today. Every piece of this car has pretty well been repurposed from other projects and lord knows how many thousands of hours went into those projects, how many sleepless nights, how many minds, how many fingers scarred (Dr. G holds the record) and it is great to see the memory of that effort and the people written into the material of its manufacture.
This car was made by many, all who share the Spirit of Sunshine.
Reverend Hedgash.
kiwi belly tank
Electromotive were the pioneers in crank trigger ignition back in the 80's but didn't really pursue the V8 world but rather the Porsche stuff.
They still support all there systems right back to day one. NRE uses Electromotive on all there engines, I have two older Tech 3 units on my turbo'd Keith Black with Moran 500 injectors so I wouldn't be too keen to throw money away by going to something else for no good reason.
In for a penny, in for a pound on the Electromotive - Just the ignition on the BMC, as we ran a carby, but will be upgrading on the Rover with EFI.
I really like the programmability and the dash board of the WINTEC software.
Dr Goggles
Quote from: kiwi belly tank on January 21, 2016, 09:52:44 AM
turboed Keith Black with Moran injectors...... the earth just shifted on it's axis.....
Lynchy
Sid
The Electromotive units we had back in the 80's were the HPV-1 and I had a HPV-3. By todays standards they are like using an abacus as a computer. A fitbit has more computing power these days. But they were great products. I seriously doubt that the one supplied with the engine is that old. I still think it would be more productive for the guys to use a computer that they already have backed up by help from one of their many friends who has that specific experience. The alternative is to use the Electromotive if it is mapped as per how the guys want to run the engine and they learn how to use it. If it has to be remapped, they can change it for one that they have better access to experience for.
