Australian Belly Tank
Dr Goggles
Yeah, when it was built they wanted the radius rods.I'd lean toward Sid's opinion myself... Some may remember that this is a GM housing with Ford axles and tubes. We had some hollow bar turned down and pulled it into the axle tubes from the housing, at a minimum it's 5/8 wall, it is very much Over-engineered.
L'tle ballast never hurt anybody.
salt27
Instead of building a new crossmember for the gearbox would it be better to utilize the mounts on the scattershield?
kiwi belly tank
Quote from: Stan Back on May 01, 2017, 04:13:14 PM
We talkin women or Bonneville cars young Stan? :-D
Dr Goggles
Quote from: kiwi belly tank on May 01, 2017, 06:10:51 PM
As long as it's respectful were open for both kinds of blabber, I've raced flyweights, middleweights and the upper classes, there is no discernible correlation between their ballast and their propensity to stay the right way up. Some of those crashes I'll happily admit were down to my driving, others had built handling problems, some the direct fault of others and the rest were just down to acts of god.
The Colonel's correspondence on this matter should be ignored, likewise the Reverend's.
I'm not trying to be a smart a$$ but would this not be a good time to rebuild the back of the car such that the rear axle bolts in? This would not only allow you an easier way to change the pinion angle but you could carry a spare axle assembly so you didn't have to go through the major work you have to do now to change a ratio.
Dr Goggles
What is a likely change Pete is that we will sandwich the main supports for the rear end so we can tilt it away for a ratio change. We're not taking an extra rear assembly with us.
We aren't sure that the pinion angle is wrong , yet.
That arrangement that we have may seem to some brutal and dumb. However there is some reasoning. As the car has no suspension it would be problematic if the rear end wasn't as stiff as it is because it would steer the car when it was loaded up, brutal and dumb, but the car drives straight.
Some would wonder why we didn't bolt it in in the first place?...... I dunno.
awelker
I would stick with the radius rods and use them to your aero advantage.  These wonderfully fashioned foam board and duct tape rear axle fairings were good for a 4 mph increase.  The only downside was explaining to my wife why $10 of duct tape did more than any other changes I had made which cost just a bit more.
Speedweek 2016 by Andrew Welker, on Flickr
Dr Goggles
That my friend got a lot of laughs at our place. :-D :-D :-D
grumm441
Now there's a solution to a problem neither of us had thought about
and it looks good
Dr Goggles
Quote from: grumm441 on May 02, 2017, 03:19:28 PM
and it looks good
You just haven't looked closely enough in my sketch book, I was thinking about it again the other day :wink:
wheelrdealer
I love the duct tape foam board axle streamlining but I am looking at the polish job on that tank must have taken a lot of time and a ton of compound.
Dr Goggles
It's a stunning ride, no two ways about it :cheers:
tauruck
Damn straight. Fairings in Yellow for Sunshine. :cheers:
