Australian Belly Tank
Dr Goggles
Quote from: Seldom Seen Slim on May 14, 2016, 09:33:20 AM
Goggs said:   "...the significant dwell-time of the piston."
How elegantly stated.  Did you, in a previous incarnation, perhaps write ad copy? :roll:
Indeed my friend I did not. :roll:
prolly not much different than ----writing songs
grumm441
Looks like the inside of a bike at work
Dr Goggles
Why, do you commonly find an undamaged rod bolt hiding in the corner of the crankcase?
My diagnosis was that someone put a piston in it and didn't do one of the rod bolts up properly, it came out and it all went downhill from there. Thing is, with a mulcher they regularly stop in a hurry after some sort of clattering crunching racket.....
This is my first time, between posting cats and hikers on Facebook,
to have read 4 or 5 pages in one sitting. My reading retention has
slipped drastically. I understood the works related to Greek couplers
because they were used in several different applications in Treit's
streamliner. Other than varied separations of the floor boards
none of it made sense. So I'll check out  and go back to converting
Kepner's drag race info from MPH to Metrics Per Hour. I'm secure
doing that because few of the readers, on the Green side, take the
time to check the math. If I error it is always to make the metric
number slightly larger than the conversion factor generates. The
only problem is that the car can never achieve the same number
that I present when it goes to their racing venue.
This is my contribution to a already confused situation.
Dr Goggles
That was the most sensible thing anyone has posted here for some time.
So, the Chev, it turns out is a little longer than the Buick because of the front set arrangement and dry sump pump. So we'd like to find some room, the Greek coupler will give us that. We need a new bellhousing, and flywheel. A lakewood will take care of the bellhousing and scattershield requirements.
We need to get the motor up to our dyno guy where we'll get going on the program to get it and the engine management happening...
I have to do some slight changes to the frame.
I have to mount the engine plate....
there you have it. Now, back to the cats and flowers Freud.
kiwi belly tank
So whats the plan here M8? Are we doing a piggy back with Johnboy's stuff to Sydney....somebody had a scattershield a few posts back...??
salt27
Quote from: kiwi belly tank on May 22, 2016, 11:30:33 PM
I got the scatter shield.
we are spread from Colorado, Idaho and Oregon.
Lets get a plan together.
Dr Goggles
Grumm? got an address?
If you guys can tell us what the freight is to get it to Kentucky we'll front the spondoolies.
Guys who live in wooden houses. :roll:
kiwi belly tank
If it's going to Kentucky or Colorado or anywhere else here in Usa, I'll spring for the couplers & the freight to there.
salt27
#5095
Quote from: kiwi belly tank on May 23, 2016, 03:18:02 PM
Like wise with the scatter shield.
The scatter shield with the block plate bolted to it might make a good shipping container.
Would the couplers fit inside?
What's Johnboy shipping?
kiwi belly tank
Yeah, they'll fit.
I have an address for Johnboy, I just need a destination decision. :?
Dr Goggles
I reckon best if it all goes to Johnboy's, they were sending the beer machine to Sydney in June or July, we can get it put on a truck from there. Even a rough estimate on 60lbs 15x15x10 inch us to Aus was over $350USD from USPS...
Grumm, are you still  breathing?
kiwi belly tank
Yeah I know shipping to there is killer. How the hell are we supposed to build cheap $hit!  :-P
I'll send the Greek's to Johnboy over yonder on Walton's Mountain tomorrow, let him know they're cummin.
I'll pm Don with the address.
Dr Goggles
