Australian Belly Tank
kiwi belly tank
What was the story on the flywheel, did you get to the bottom of that?
salt27
Grumm, Goggs, do you use a manual or hydraulic clutch release?
What kind of throw out bearing arm?
stay`tee
James, I have used a shipping company from the Sunshine coast called "Californian Image" (calimage.com.au), thay have a base in LA and offer reasonable rates, maybe give 'em a call for a quote,  :-)
kiwi belly tank
Greek Couplers shipped to Johnboy today.
Dr Goggles
Quote from: stay`tee on May 24, 2016, 04:34:53 PM
Thanks Ronnie
Quote from: kiwi belly tank on May 25, 2016, 01:51:48 PM
Cheers Sidney.
kiwi belly tank
Hey smartarse......I mean Gogg's, I meant to ask, do you have a collapsible or solid spacer in your pinion bearings?
grumm441
Quote from: kiwi belly tank on May 26, 2016, 08:48:20 PM
Yes
Quote from: salt27 on May 24, 2016, 04:20:13 PM
Hydraulic
Quote from: Dr Goggles on May 24, 2016, 03:19:33 PM
Grumm, are you still  breathing?
Breathing pure plaster dust
Dr Goggles
Quote from: grumm441 on May 26, 2016, 10:38:00 PM
Yes
He right you know.
kiwi belly tank
He the brains you the looks right? :-o
Dr Goggles
I guess you got that, not everyone can be both like you Sid.
G has a little bit on just the last few days, once he has a chat to our dyno guy we may be able to shed a little light on the flywheel situation.
salt27
#5110
Goggs, Grumm, The scatter shield is boxed up, I just need to drive to Roseburg to get it shipped.
I'll try for Wednesday.
Dr Goggles
kiwi belly tank
Quote from: Dr Goggles on May 29, 2016, 01:16:26 AM
I try not to look in the mirror, there's always some old fart in there! :-o
There's some odd combos in the 4.3 cranks but you should be able to get info from Duttweiler on what you have.
grumm441
Quote from: kiwi belly tank on May 29, 2016, 08:28:36 PM
If the flywheel was an odd thing it wouldn't have made sense to take it off as I wouldn't have thought it would be much use for anything else
It's a one piece seal on the crank and has a six bolt pattern with one bolt offset.
So I 'm going to grab a Monaro bell housing and flywheel  down from the roof
and see how the gearbox looks bolted on and see how much bigger the other box I have is
Now if some one had a Bert box lying around....
Ian Powell the dyno guy may be coming by on tuesday night for a look. to work out what how he's going to hook it up
Busy, me, yes. Between Moto Guzzi clutches and Vincent wiring looms. you could say I'm busy
I've got more work at home than at work, and then there's the home renovations.
kiwi belly tank
I believe the one piece seal "stock crank" uses a counter weighted flywheel but a "stock crank" in not normally what you'll find coming out of Duttweiler. I bet its got splayed bolt steel main caps & an after market crank under it. I would contact Duttweiler, they'll have records of it.
